I have one on the way, but it will be a week before it get's here I'm sure. I'm considering switching to a dual motor setup with new Stingers & 4mm drives. Will know when I actually get to see the hull and what it will take.
________ Extreme Vaporizer Review
I bought a Genesis hull, only the hull painted and with the stickers directly from the factory.
Setup will be a twin motors with 6S. 6S for each motor in parallel
I' m thinking for 1700kV motors, 37750 RPM unload, what do you think?
Tiqueman, how is the hull, same quality or better than the HOTR cat?
Please can you post pictures?
T- is it the same size at the apparition width wise? I was hoping it would be wider.
Thanks for posting the photos, that's a nice looking paint scheme. I like the # too. 72 is Pegrams AMA number. My old race number was 70. Love the 7's. =)
________ Nevada dispensary
Its exactly the same width as the HOTR. But, I wouldnt rule it out. Although I havent run it yet, Stevens vids seemed to show it handle better than everyone thought. I like the hull design because it comes to a tru point under the sponson rather than a flat spot. Should be able to handle a decent chop, again, Stevens vid proves that as well.
Thank you for the pictures
What kind of finish is this, paint or stickers?
Its a combination of both. The yellow and red up the bow seem to be decals, as well as all the white pin striping. The black, orange and silver are paint and the windshields a decal. Very nicely done though. Im impressed w/ it. Clear is nice and thick and really makes the paint look deep. BUT, Ive heard from more than one that it chipes easily while removing hatch tape. I just need to remember to pull it off slow and at a 180 peel back to try to prohibit paint pull. I even thought about getting some 3M clear vinyl and lining the hatch and the hull around the hatch w/ an inch and a half or so of the vinyl (on each part) and tape on top of that. That way your pullin off of vinyl.... as long as the vinyl gets a good adhesion... in theory, it should work
Yeah, I lined the rear of the KOS with PVC tape and just do a tape to tape, as it pulls off the pin striping on removal.
Good note to be careful of the paint pull. Another help might be to wax it lightly. I use stuff called Liquid Glass, which allows the PVC to stick, but removes easily. It was originally designed for fiberglass Corvettes and works well on fiberglass bodies. (been using it for years on my fiberglass race bodywork)
________ Cb-1
I bought my GENESIS hull from manufacture and I will tell you more when I will receive the boat.
What do you think about that twin setup, 2x3S 5000mAh and 2 x Tenshock 2240 1700kV? Thank you
