Good target RPM?
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    Good target RPM?
    I'm curious about the target RPM for a brushless setup.
    What is too high? What is too low? What is just right?
    How do I know?
    Right now I'm targeting 29 - 32k Peak RPM by V x Kv method.
    ________
    HERBAL VAPORIZERS
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    I guess this is a really silly question, or just too vague?
    ________
    Chevrolet big-block engine specifications
    • Jeff Wohlt
      • 2740
      Those are good rpm levels as long as you do not over prop. I like 27-30,000. Also depends on the motor...some can keep it up while others can't.
      www.rcraceboat.com
      jwohlt5362@yahoo.com
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3784
        Is that actual or theoretical peak?
        ________
        30 Rock Advice
        • Jeff Wohlt
          • 2740
          Based on non-loaded rpm so you will be down to 24,000 or so.
          www.rcraceboat.com
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3784
            Nice.
            I've heard of a few running 4s 2700Kv without any problems, which is nearly 40k RPM.
            What is the main reason 40k is too high and 32k is not?
            ________
            WEATHER EYE
            • Jeff Wohlt
              • 2740
              Well a good balanced motor can do that but the cheapos out there will throw parts, bearings or something. You can do it for a while but it will go.
              Now a NEU or Castle can probably handle it but they have more thorque than rpm in most cases.
              www.rcraceboat.com
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3784
                Oh, so it's about shaft balance and the bearing system. That makes perfect sense. Really, I think spinning a dremel shaft at 30 KRPM is kinda surprising!
                Thanks for taking the time to clarify this, it's a bit confusing putting all of this together, I'm still wet behind the ears when it comes to building and calculating.
                ________
                Vaporgenie reviews
                  • 9481
                  it also depends if your sport boating or going after a SAW record
                  take the SV27 has an unload rpm of about 27,000rpm
                  and the UL-1 is about 30,000rpm
                  and some SAW runs are 40,000rpm +
                  • Simon.O.
                    • Oct 2007
                    • 1611
                    I am a solo boater and the pond I run mostly in is good for staight runs, I run anywhere up from high 20kprm to high 30krpm.
                    It is safe to say that some of my setups are close to SAW type.
                    I like small props and wicked rpms, it just sounds nice!
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3784
                      This really clears up the RPM range thing. I'll stay away from over 30k with anything that I don't feel is completely balanced and of good quality bearing/drive setup and shoot for 26k with cheap stuff. =)
                      ________
                      New Jersey Dispensaries
