Tunnel Hull setup
  • F1 boats
    • 87
    Tunnel Hull setup
    Hi info need
    I have a 36 in Fibreglass tunnel hull that weight is 1.44kg bare hull
    was going to run it on 4s plenty of room to run 4s2p
    had in mind to use a neu motor 1515 or 1518
    should i run an outboard setup like the 3.5 bullet or should i run a strut and rudder
    Thanks
  • Heath M
    • Mar 2008
    • 865
    Hey Peter thats a big boat m8, you'd be better off with the 1518 1800kv castle/neu and a big prop
    Heath
    Brisbane,QLD, Aussie
    • properchopper
      rcgoatbuild@snotmail.com
      • 7708
      If you run a motor like the 1515 or 1518 with a Bullet drive or any other lower unit with a .150 cable you'll break cables immediately. A 7.5 lower with a .187 cable is what you'll need.
