3060 kv ?
  • steve-b
    • Mar 2010
    • 274
    3060 kv ?
    Hey guys,
    I put a 3060 kv motor with a 180 ESC in a vagas hull with two 5000 2s 40c batteries in series. this thing went fast. The batteries were a little warm after about 3.5 min of running. I was using the stock prop.
    Whats wrong with this setup? Do i need to use diffrent batteries? It seems to work good with that prop... bit of cavitation out of the hole.
    Whats going to go wrong?
    I hope someone can help.
    Thanks.
    Steve.
  • Rumdog
    • 6667
    Too much kv. On 4s you want around 2000kv. You were probably pulling huge amps! What motor is it, and what size prop?
    • steve-b
      • Mar 2010
      • 274
      The motor is a 3660 HK, im not sure what the prop is, dont have it here, probably around 36mm.
      This was just for fun. I gutted and converted the vagas in about two hours. I hade the motor on the shelf. What would this motor be good for?
        If the Kv is accurate it might be a good 2S-3S motor - just like it says on the data page. Personally I think that 3S is probably too much for most applications.
        Choosing the right domain name can be overwhelming. Our personalized customer service helps you get a great domain.
