Carbon filled props? Two blade? Three blade?
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    I'm toying around with a new boat and thinking about trying the Carbon Filled props. Cheap and no prep time required makes them very appealing.
    I'm using the stock plastic props, so this should be a nice upgrade.
    Any draw backs that should be considered?
    Should I go with 2 or 3 blade?
    ________
    FERRARI 248 F1
  • slyman
    • Jan 2009
    • 126
    I had no problems using them with a pair of 2s lipos. I have changed to a pair of 3s lipos and the props self destruct. I don't think they can handle the higher RPM's generated from the 3s lipos.
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      What Kv motor? What size props?
      ________
      Vapir No2
      • slyman
        • Jan 2009
        • 126
        1500kv motor
        K series 40, 42, and 45mm
        4mm threaded props 36, 39, and 42mm
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3784
          How long did they last before coming apart?
          ________
          Ford model n picture
          • slyman
            • Jan 2009
            • 126
            Within one minute.
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3784
              Ouch.
              ________
              Sauteing
              • Simon.O.
                • Oct 2007
                • 1611
                Fwiw I have setup that is good for close to 30krpm at the prop and have run a few of the CF filled props. They last seconds, a minute at best, but gave me the info that I need to now buy a good metal prop.
                This was running a CF 442 on a 9XL fed with 5S in my big cat.
                CF props have their place but not on bigger power setups, for me at least.
                I will continue to use CF props for testing and running my smaller setups.
                • GregS
                  • 82
                  How exactly are these props destructing? I got some Graupner K-Series 45mm CF props for both a mono and a hydro running 4S with SV motors/ESC's. I haven't run them extensively yet but haven't had any issues with a few short runs. They perform as well as the metal props as far as I can tell.
                  Greg
                    • 7512
                    I'm running 48mm props on my 29 Delta, and a 51mm on my 1521 4S powered 31" Cat with no issues.
                    Never had one break over the years unless I ran over something.
                    • electric
                      • 1973
                      I have used the CF props off and on and none had failed, except when I hit something underwater etc. They are pretty good. The beryllium(sp) ones are much better of course, but still, if you are watching your budget they are a good buy.
                      • JimClark
                        • 5913
                        We have 1/10th scale hydros using the 45mm graupner for a long time on 4S and they do not self destruct
                        Billy Graham
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3784
                          Nice. I bought a few for testing, etc. I'm quite optomistic about them. My current estimated peak RPM is right around 30k.
                          ________
                          Mercedes-benz m123 engine
                          • slyman
                            • Jan 2009
                            • 126
                            I will say again-I had no problems running the carbon fiber props when I was running a 4S set up. The props cannot handle the higher RPM's should you go to a 6S set up like I did.
                            • Steven Vaccaro
                              Administrator
                              • 8932
                              I've run, raced and won while using carbon props. I have no issues running carbon props on boats that run 40-50 mph with 7xl or 8xl motors. Most of my boats are setup to run in the 25k-30k area. More than that isnt needed for my personal setups. If a person needs more rpm than that, they should also have the ability to sharpen and balance a prop, so use metal.
                              Steven Vaccaro
