hv hydra esc
  • 2fast
    • 22
    hv hydra esc
    what hv hydra esc will be good to use with the neu 1415 1500kv motor on a prather lap cat III? also what batterie?
    thanks
  • Raydee
    • 1619
    Why are you going for the HV series? Are you planning to run 6s or more?
    Team Liquid Dash
    • 2fast
      • 22
      its a 36" cat wont i have to?
      • Raydee
        • 1619
        That motor may be a little small for a 36" hull BUT since its a outboard it may work or may not. THe bigger problem that you will have is running 6s on a 2200KV motor. You are looking at over 48,000RPM......NEVER going to work in a tunnel hull.
        Are you planning to run it SAW only? If that is the answer I can't help you there, I only run oval.
        Team Liquid Dash
        • 2fast
          • 22
          no i run oval so what motor do you recomend for 6s? or could i run 4s on the motor posted above?
          • 2fast
            • 22
            how about a 1521 1577kv and a hydra 240 on 6s ?
            • Raydee
              • 1619
              Sorry I misread your post (not the first time). Your 1500 KV motor will be a little hot but def workable on 6s. I ran a 1500KV motor on 6s and it was very fast. For a 36" Boat I run 1527 motors but I think in a outboard the 1521 would do just fine. As far as a ESC goes I have a feeling the Hydra 120 would be a little to weak but the Hydra 240HV would be overkill and hard on the wallet. Might want to try that Swordfish 240HV that Steve is selling.
              Team Liquid Dash
              • 2fast
                • 22
                ok ill check that esc out to. thanks for the help (im a newb)
                -matt
                • 2fast
                  • 22
                  could i use this mount as an adapter to use the 1521?http://www.offshoreelectrics.com/pro...od=ose-drmount i would need it to mount to this kit? http://www.offshoreelectrics.com/pro...5-bullet-drive
                    • 7512
                    There are lots of "inexpensive " controllers out there for a lot less money than the Castle controllers (Turnigy 180) comes to mind and are proving to be very reliable.
                    OSE sells Swordfish and Etti controllers as well.
                    • 2fast
                      • 22
                      yes i think i will be going with the sword fish but will the 1514 1500kv be enough motor on 6s if not what do i need to adapt the 1521 or 1527 to this kit? http://www.offshoreelectrics.com/pro...5-bullet-drive
                      thanks
                        • 7512
                        Personally, I've never seen or heard of that large of a motor being used on an outboard.
                        I think that on 6s, the cable might have a hard time surviving.
                        Have you considered a Fiego xl series motor? It will fit that drive. The bigger Neu's would need some sort of custom adapter plate I would think.
                        • 2fast
                          • 22
                          the neu 1515 and 1514 fit with no adapter but i was not sure if they would be enough for my boat. after reading what you said, they should be? thanks.
