Another dumb lipo question
  • Doozie870
    • 970
    Ok I picked my packs up today 2x 25c 5000 7.4 flight powers with 1 flight power v balancer. Im going on 3 hours of bleeding/balancing on the first pack is this normal?
  • Rex R
    • 1007
    er, possibly, what is your pack voltage(s) CHECK NOW. IF OVER 8.4V UNPLUG IMMEDIATLY! now that I've gotten that out of the way...what charge rate are you using?
    • Doug Smock
      • 5359
      That has not been my experience.
      Did you charge them? If so were they in balance before you did?
      What is the individual cell voltage?
      Where can I go read about your charger, ballancer?
      Man you just thought you had questions.
      Doug
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • Doozie870
        • 970
        The packs have never been charged in fact they dont even have ends yet, Im using the balancer as a stand off only unit.
        • Doug Smock
          • 5359
          Doug
          This would be helpful.
          Doug
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • Rex R
            • 1007
            mine have not required more than a minute...methinks you had better check your cell voltages. my balancers(hypereon) require the main charge leads to be connected(with in 12 sec.s of plugging in the taps) to balance the packs.
            • Doug Smock
              • 5359
              I was thinking the same thing. Did you "RFM" Doozie?? LOL
              Doug
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • Doozie870
                • 970
                The total voltage is 7.20 I tried the tap for voltage per cell and got 3.44 and 7.2 the rest were 0. I unplugged everything, the charger is a graupner duo plus 30 hobby-lobby, (it has not been connected yet) the balancer is a flight power V-balancer model fp-b6s from tower.
                • Doozie870
                  • 970
                  Yes I rfm'd lol, it said balancer can be used as a stand off unit with just the tap wires connected and if the light was flashing it was balancing and not to procede.
                  • Doug Smock
                    • 5359
                    The individual cell LEDs are blinking or the mode LED is blinking?
                    Doug
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • Doozie870
                      • 970
                      Plugged back in after reading the manual again,,apparantly this will continue until each cell is within 5mv of each other. right now im 3.76 and 3.44
                      • Doozie870
                        • 970
                        just the #2 cell light is blinking
                        • Doug Smock
                          • 5359
                          I don't have any experience with any cells other than the Neu 4900s.
                          None of the cells were out of balance upon arrival. 4-4s 4-6s and 8-2s.
                          I don't know if your situation is cause for alarm or not. I would think that if they continue to take that long to balance there may be an issue with them.
                          Hopefully someone that has used these cells will chime in here.
                          Good luck sir,
                          Doug
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • Doozie870
                            • 970
                            Thanks everyone, the slightly higher voltage cell is coming down just very slowly, this balance bleeder rate may be adjustable ill dig into it, thanks again.
                            • SJFE
                              • 4867
                              I balance my packs on stand alone now. Then chagre them & repete. I dont like charging them through the taps anymore. Not after blowing my first balancer sky high...lol
