Small cat problems.
  • speedsport
    • Mar 2010
    • 49
    Small cat problems.
    I have a Nanokat its about 15in long. I'm using a Mystery Pentium 30 esc and a Mystery 4000kv outrunner. On 8cells NIMH with a octura x427 prop set at the bottom of the hull as a surface drive.
    I use to use a novak esc and a speed 400 motor. My problem is that this brushless set up is about as fast. I think the motor is a 12 pole design. I tried a bigger plastic prop a y534 and noticed a little better performance. With the smaller prop the boat takes longer to plain out and bounces no matter what I do. The bigger one is the exact opposite. I also noticed with the bigger prop it sounds like the motor is barley spinning.
    Neither prop makes any thing hot its just warm to the touch. I got about 30 run time with the small prop and about 20 with the bigger one.
    Should I switch to a different motor, prop or esc? I would like to stay with the cheaper stuff as this is just for fun. I'm new to the brushless stuff its greek to me.
    Thanks.
  • speedsport
    • Mar 2010
    • 49
    I just realized I worded this weird. I'm trying to figure out if there is a way to make it preform better, faster.
    Thanks
    • Rumdog
      • 6667
      Switch to lipo. A 2s pack would be plenty.
      • Rumdog
        • 6667
        A lower kv motor around 3000kv and 3s lipo would be even better.
        • speedsport
          • Mar 2010
          • 49
          Thats what I'm talking about thats the kind of stuff I like to hear.
          I'm planing on going to lipo on every thing. I thought about using a smaller KV motor but was not sure. What about the 3000kv on 2s would it work? Or would I have problems?
          Thanks
          • Simon.O.
            • Oct 2007
            • 1611
            It was noy long ago that i was running Ni cells when the rest of these guys were telling me to go lipo, I eventually fell and will never go back.
            The joy of Ni cells is you can add a cell and the effective rpm of the motor increases a bit. Add a cell with Lipo and it all gets a lot faster.
            Choosing a motor (kv) is important when specing a power setup with lipo.2S is a lot differet to 3S etc.
            You currently have a 4000kv motor with a 427 prop and 8 cells.
            Now given that Ni cells loaded will deliver about .9v/cell you are getting 7.2v loaded.
            Now take a 2S lipo which has a nominal voltage of 7.4 and you are already ahead.
            For a 2S setup I would run well over 4000kv to a 427, it will do but you can do a lot better.
            If you are up for a new motor then I would suggest that you look at a high kv motor for 2S or a moderate 2800-3500kv for a 3S setup.
            The lower kv and higher cell count setups are lower on amps and therefore easier on components.
            I have done a lot of reading on small setups as I am in the process of putting 2 more cats on the water.
            I hope this was a bit of help.
            • speedsport
              • Mar 2010
              • 49
              I was thinking on another motor. What about the prop? I could change that to if it will work better.
