.150 cable to 3/16 stub?
  • tjsb
    • Mar 2023
    • 478
    Does anyone know of one that is welded not glued together.OSE is out of them and Zippkits are glued.
  • 1coopgt
    • Feb 2019
    • 417
    If you're good at soldering you could buy the .150 raw flex shaft and the 3/16" stub shaft from the OSE store and make your own. There are videos showing how to do it on You tube.
    • leski379
      • Jul 2023
      • 99
      I just needed the same cable and I ended up using a proboat veles cable I had laying aroung. The proboat shreddy uses a similar cable I believe. They are crimped to the stub shaft.
      OSE has 1 upgraded proboat veles cable in stock that looks different then the factory proboat ones. I'm not sure if it is long enough for you though.
