Motor Mounts Keep Breaking Loose.. Help???
  • NativePaul
    Greased Weasel
    • 2770
    Epoxy and Polyester do not bond together well, try one of the other glues recomended here.
    • Brod
      • 196
      Originally posted by Rumdog View Post
      It's prob. because the tunnel is flexing from the inertia of the crash plus the weight of the motor. Stiffen up the tunnel floor with some glass or cf.
      Agreed,floor is bending and flexing,loosening the bond on the glue/hull.
      Slow gets boring fast.
      • ED66677
        • 1300
        that's why I kept the plywood rail... no epoxy no CF no nothing!
        Emmanuel
        • properchopper
          rcgoatbuild@snotmail.com
          • 7708
          The solution is in post #13.
          • Alexgar
            • Aug 2009
            • 3701
            #35
            i like jb weld also
            • Tuslow1
              • 154
              #36
              Well my CF came in today and I think I ordered a tab bit too much, but the good thing is now I know how big 4 yards really is and I don't think I'll need anymore for some years to come.
              I was looking at how pretty and wet the CF looks thinking to my self "Damn thats alot" when the Fun Governer said "and you better use it all" as she walked out of the room!!!
              OK, You Go First!!!
              • Tuslow1
                • 154
                #37
                Now back to the "JB" topic, just mix it 50/50 and that will bond the mount inplace for life? No micro balloons, baking soda or cement mix?
                OK, You Go First!!!
                • AlanN
                  • Mar 2008
                  • 334
                  #38
                  JB weld is for those who do not know how to use epoxy correctly or do not use the right epoxy.
                  West Systems or Mas.
                  Of course alot has to be said about how your mount is designed and made.
                  I bit my tongue on this topic for days....just couldn't stand it anymore.
                  • Doug Smock
                    • 5359
                    #39
                    Originally posted by AlanN View Post
                    Of course alot has to be said about how the design of your mount is created.
                    Me too.
                    I have never had a motor mount come loose and I crash as hard and often as the next guy.
                    Crashed a mono at 88mph, tore the aft portion of the deck off, but the motor mount stayed in the boat.LOL
                    FWIW I've had good luck with 30 min Z-Poxy.
                    Carry on JB Welders!!!
                    Doug
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • BakedMopar
                      No Mo Slipah
                      • Sep 2009
                      • 1743
                      #40
                      JB weld is for those who do not know how to use right epoxy or do not use the right epoxy.
                      Thanks for establishing that we uneducated. It however does not answer the OP.
                      • AlanN
                        • Mar 2008
                        • 334
                        #41
                        No baked mopar it does not directly answer the question. But 30 minute epoxy (and there are different grades out there) does not hold or cure as well as top shelf epoxy. There are plenty of good suggestions here but I am not going to repeat them. Stiffen the hull...use rails....did anyone think of a rear support for the motor? Longer cans have more leverage against the mount. I have seen jb weld used for everything but in the end it always dries up, becomes brittle and breaks anyways. Besides that it looks like $%^# in a hull.
                        • BakedMopar
                          No Mo Slipah
                          • Sep 2009
                          • 1743
                          #42
                          I have been using Hawaii Fiberglass Marine epoxy with great success up until now. My boat consists of 4" rail that extend 14". Motor mount is front and rear support. The Rico hulls have virtually no flex ( it does have a carbon floor). The rails just did not stick to the hull. I could be that the hull is not fully cured yet? I re-did it with the marine 5200 ahesive. Hopefully it holds better.
                          • 6S HYDRO
                            • 1325
                            #43
                            i agree about the look of the jb weld in a boat
