Is this to much angle?
  • d.g
    • Apr 2010
    • 8
    Is this to much angle for my propshaft?
    Its about -10 degres from the horizontal.
    Thanks
    Dylan
  • steveo
    • 1595
    yes you want to be parallel with the bottom of the boat, if you are trying to keep the nose down adjust your batteries more foward
    • d.g
      • Apr 2010
      • 8
      okay thanks for the info.
      dylan
      • Gary
        • Jan 2009
        • 1104
        Your water tube is going to pop off aswell . You should have a one piece pickup not two with a hose keeping it togather. Before you realize its goe everything will go POOF !!! Not good.
        H&M 1/8 Miss Bud 73 mph
        Chris Craft 16 mph
        • d.g
          • Apr 2010
          • 8
          okay thanks. I'll make a new one tomorow.
          Dylan
          • steveo
            • 1595
            lets see some more picks of the hull and interior
            • Rumdog
              • 6667
              Is the rudder going to be in the water? Looks awfully short. Cpould be the pic though.
              • d.g
                • Apr 2010
                • 8
                hmmm yes i think you are right. I was planning on making another one anyway. Im keeping it brushed because i cant afford brushless and i already had the motor. Its a scaled and cut down wild thing.Here are a few more pics.
                Dylan.
                • steveo
                  • 1595
                  did you retain the angle of the drive line because it is a straight shaft or is it a flex shaft
                  • d.g
                    • Apr 2010
                    • 8
                    Its a wire drive. There's less angle now because i moved the motor more to the front of the boat.
                    Thanks
                    Dylan
