To buy a "water damaged" M-Machine with or without hardware?
  • Karfrik
    • Jun 2009
    • 1248
    Is it worth paying the xtra $30 for the MM with hardware or not? aeromarine is still selling them at $60 w/out and $90 with hardware.
    Whats your experience? recommendations?,...Thanks,....Albert
  • justintime2w8
    • 323
    30 seems cheap for hardware, wonder what it looks like.
    www.radtekpowerboats.com
    • ozzie-crawl
      • Sep 2008
      • 2943
      thats cheap for hardware, from what i understand there a different hull to the one steve sell
      still a good hull lots of conversions to FE
      • Karfrik
        • Jun 2009
        • 1248
        anyone have an actual MM stock hardware picture?,......Al
        • ozzie-crawl
          • Sep 2008
          • 2943
          fairly sure this is there rudder/strut of the hull
          and the yellow hull shows them on
          • Karfrik
            • Jun 2009
            • 1248
            ozzie,so is it worth the xtra $30? are this your personal boats?.....just want to know if to go with the stock hardware or just spend a little bit more and get me something better for the MM hull.................thanks for the pics!!,....Al
            • teach
              • 509
              I have a rudder from one. Nice piece. Order one with and if you decided not to use it I'll give the 30 bucks if you wanted to sell them.
              • Karfrik
                • Jun 2009
                • 1248
                Teach,that sounds like a deal!!!...i`ll let you know if i decide to.Stay tuned,....thanks,Albert
                • teach
                  • 509
                  To be honest I won't hold my breath on getting them. When you see the quality stuff they put on the boat I doubt I could pry it off you
                  • Karfrik
                    • Jun 2009
                    • 1248
                    probably ordering my MM next week.What setting are you running on it? and what motor mounts are you using? do they come with 4" or 5" rails on them?....Thanks,Al
                    • rchippie
                      • Jan 2010
                      • 640
                      I would also like to know what size motor & lipo are needed ?.
                      • Rumdog
                        • 6667
                        They come with no rails. If going chinese, you want an xl can. 8xl on 4s, or so on to get the rpm correct. Obviously more volts plus lower kv is more efficient. Acastle/neu or neu 1515 1y on 4s will be very fast. It all depends on what you want out of the boat, because the hull is excellent in handling and speed.
                        • rchippie
                          • Jan 2010
                          • 640
                          Would a ul-1 motor on 4s be okay to use ?.
                          • lectriglide
                            • 540
                            No rails. Another thread with a pic of how they come inside (see post 9)
                            http://forums.offshoreelectrics.com/...hlight=machine
                              • 9481
                              Well worth the extra 30 bucks!
                              I run a 9XL in mine on 4s and 5s and it kicks
                              I would kinda like to try a 580
