bouncing boat!
  • Diegoboy
    • Mar 2007
    • 7443
    Originally posted by bea5017 View Post
    thats not a bad idea.. u mean have the rudders like a slight v?
    No. Opposite angle as this
    This is out, you want in
    • bea5017
      • Aug 2009
      • 173
      water like glass. runnin flightmax 2s 5000's 30c in series. opto etti 150. boat pretty damn heavy def not a light 1. ill have to post a few pics once i get home from school. it was my first true FE, ( on my second right now) i cant ever seem to get this damn mono runnin right
      • Diegoboy
        • Mar 2007
        • 7443
        Set your strut angle to neutral (straight) till you stop the bounce.
        • bea5017
          • Aug 2009
          • 173
          gotcha. will have to see if i can mod them as they are as far back as possible and its pretty much straight up n down
          • Diegoboy
            • Mar 2007
            • 7443
            The image is grossly exaggerated for ease of understanding. the angles need to be very slight.
            • bea5017
              • Aug 2009
              • 173
              yeah i know.., it may be slightly how u described now, very slightly
              • Diegoboy
                • Mar 2007
                • 7443
                Can you take a pic of the transom & bottom please>??
                • bea5017
                  • Aug 2009
                  • 173
                  if i wasnt at school...... i will though, i wont be home till next tuesday. ill see what i can do now though tryin to get my mom to take em if shes not sleepin hahaha
                  • bea5017
                    • Aug 2009
                    • 173
                    best i can do for the moment
                    • justintime2w8
                      • 323
                      Have you played with the CG at all, you might push it forward a bit just to see if it helps.
                      www.radtekpowerboats.com
                      • bea5017
                        • Aug 2009
                        • 173
                        battery placement limited by a bulkhead i put in gonna try other stuff b4 i start cutting
                        • justintime2w8
                          • 323
                          Ok, been there done that. Tape some weight to the bow and run it. See if it helps.
                          • bea5017
                            • Aug 2009
                            • 173
                            if it come to that.. the front stays level, but the whole boat is in the air! worst case i will, i only have had 1 run in wit it so ima mess with some other stuff to get the gurl to stay wet ; )
                            • justintime2w8
                              • 323
                              Ok, how about prop depth, not angle, but when you put a straight edge on the bottom of the hull how high is the prop in relation to the bottom of the hull. Some times you can lift the prop and settle the hull. You may have to adjust the height at the transom by moving the whole strut up.
                              • bea5017
                                • Aug 2009
                                • 173
                                its pretty much as low as i could get it. just a hair up from the bottem. that would involve tearing the whole boat apart! i just finished it! haha ok maby that is the WORST case..
