HK Water Cooled Inrunner
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    Have any experience with this motor?
    HXT 36-56 2700kv Brushless Inrunner (WaterCooled)
    Kv: 2700rpm/v
    Required ESC: 80A
    Voltage Range: 10-18v
    No Load Current: 4.9A
    Max Load: 68A
    Max Power: 475W/60S
    Weight: 317g
    Shaft: 5mm
    It looks like it could be a drop in for the EKOS and run on 4s.
    ________
    What is love
  • Rumdog
    • 6667
    This is a 540 size motor. The EKOS would need mods
    • Make-a-Wake
      FE Rules!
      • 6057
      Kv: 2700rpm/v
      Required ESC: 80A
      Max Load: 68A
      Max Power: 475W/60S
      Weight: 317g
      Shaft: 5mm
      Are you referring to the 34" Dual 380 C1 KOS or the 35" P1 single motor KOS?
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3784
        Should have clarified: the EKOS C1
        ________
        Toyota Voltz Specifications
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3784
          FYI- These are a bolt in motor as they have two different sized bolt patterns. Pretty cool.
          I'll let you know how I like them.. =)
          ________
          Ford Boss Engine
