esc safety
  • Xfactor
    • 874
    esc safety
    As I sit here pondering my speed control on my 1/8th scale I had a light come on in my head. All i need to do to protect my speed control is put an inline fuse on the positive battery leads. There are fuses big enough to do the job. I can put a 125 amp fuse(just an example) in line and never worry about the speed control ever seeing more than 125 amps
  • ozzie-crawl
    • Sep 2008
    • 2943
    not sure how that would work, most fuses will take more amps than rated
    or take awhile to blow. trip type fuse may work.
    but i think you may find it will cause more trouble than its worth just my 2c
    • mappo
      • Feb 2010
      • 496
      Ah got it! your question is? to use a fuse , to stop your esc from getting past 125 amps. Rating, You will have blown fuses every time. most controllers will still go beyond terminal or bust amps for at lease 10-30 seconds. so you will have popped fuses going as you encounter high surges, . Most well designed controllers are conservatively rated. It can be done but, it may be more problematic. would be interested in hearing other opinions. Ps the guys at Castle may have an opinion on this issue.
      Do you know what the biggest problem with the world is?
      That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
      • bwells
        • Jan 2009
        • 847
        That link is great for initial plug-in but I think Ozzie is going after the fact, to stop too much draw to the ESC. I like the thought! Keep it coming.
        • ozzie-crawl
          • Sep 2008
          • 2943
          it sounds like a great idea but i am fairly sure it wont work
          i cant remember if its because to much resistance is created or voltage spikes but some thing along those lines, what i was trying to think of before was a circuit breaker not a fuse, a fuse quit often has to exceed its rating for a given time before it blows.
          • Simon.O.
            • 1611
            Ozzie knows more about sparks than I do.
            I do have some practical experience with fuses and breakers from a ametuer point of view. Either of them have quite high resistance which will tax the power source ( your packs ) more than needed.
            A fuse is a very slow safety device and even a fast trip CB is too slow for what you are intending. A RCD, which is at the top end of circuit protection is too slow to prevent an esc getting bent over forwards.
            A pack will provide near unlimited amps for a very short time, such as a closed/short circuit.
            The best way to prevent all of this is as follows.
            1. Spec the pack to be 125-150% of what you think you need.
            2. Spec the ESC the same.
            3. Keep it all dry
            This is how I do it and it works well so far.
            The exceptions are SAW setups, of which I have done a few. Setups not measured saws.
            I hope I was some help.
