Best setup for 32" catamaran
  • Alfa Spirit
    • 2183
    Hello guys,
    I need your advice about the best setup for a Hydro & Marine 32" catamaran with one brushless motor.
    4S batteries with 540XL 2200 kV
    6S batteries with 540XL 1500 kV
    Thank you for your help
  • Alfa Spirit
    • 2183
    Here is the hull, this is an Intruder 32" from HM.
    A friend of mine bought this boat and may be you can help me for the setup, 4S with 540XL 2200kV or 6S with 540XL 1500kV?
    Thanks
    • Jeff Wohlt
      • 2740
      The 6S will end up being a lower amp draw and better rig. of course propping righ is ket but you will being able to run larger props and a smaller ESC...like 120-150.
      www.rcraceboat.com
      jwohlt5362@yahoo.com
      • ElectricOnly
        • Nov 2010
        • 70
        Intruder Mk II 37"
        Will be running a 6S pack but you could run a 4S, 120A ESC, Nemesis Gold 482-2Y 1500kv motor. Will start out with a X440/3 Blade.
        The 482 might be a little much for a smaller boat at 4.66HP; you could go with a Nemesis Gold 474-3Y at 3.46HP.
        I only need one!!!
        • LarrysDrifter
          Big Booty Daddy
          • 3416
          A good set up would be a 180 amp esc,Leopard 4074 1400kv,two 3s packs in series for 6s total.You could run a 4082 1500kv,but it might be a little too much power for the 32".With the 1400kv,you could prop up and get quite fast speeds with less amp draw than running 4s.
          • Diesel6401
            Memento Vivere
            • 4391
            Out of the choices you have the 540xl 1500 would be way better than the 2200kv. But it if was my hull I would put a CC 1518 in it or a Leopard 1774 on 4s2p. JMO
            - Diesel's Youtube
            - Diesel's Fleet
            • ironjaws
              • Jul 2011
              • 286
              what kind of run time could you expect with the 3s in series setup?
