Hello Guys,i m needing some help from you...
I have a 41 inch rigger powered by 10S 45C desire power batteries, with a HK4035 800KV motor with a 1655 octura prop.
When i used the YGE200 i defined the timing and switching frquency,altough i now use the Schulze 32 200WK, and that parameters are defined automatically by the speed controller!
The problem is that after runing 2 or 3 minutes the speed controller and motor are hot(none of them is watercooled),but when i used the YGE200 both the motor and speed controller were a lot colder!
The setup is exactly the same,only changed the speed controller....Does anyone have experience with the schulze speed controllers?
Not only that,but after exiting a curve if i give full throttle most of the times the speed controller,cuts off,that never happened with the YGE200...you can check that one or two times in the video..
Any input would be really appreciated...
This is me,and the boat..
A small video with mine Nokia N97
Very Best Regards,and keep doing the good work
