Blackjack motor and prop for LSH
  • LuckyDuc
    Team Ducati Racing
    • Dec 2008
    • 1058
    I was wondering if anyone has tried the blackjack motor and a M645 on a LSH with any success? Can it handle this much prop on 4s 5000mah?
    I plan to start with a x642 first.
  • Rex R
    • 1007
    depends on the esc...mine ran nice on an x645, but the esc didn't like it(sv esc).
    • vasy
      • Dec 2009
      • 348
      I had it stock and x642 is max you can go. It runs just on the edge of stock ESC.
      • Hydromaniac
        • Oct 2007
        • 955
        Yes and it works great, It can can handle a lot more prop the the UL-1 motor, I run my LSH on an X442 It seems to let the motor really wind out.
        www.rockymountainthunderboats.org
        • LuckyDuc
          Team Ducati Racing
          • Dec 2008
          • 1058
          I'll be using an ETTI 150 opto ESC with mine. Any idea on amps with the m645?
          • detox
            • 2357
            I think you would be happier using the UL-1 combo. What hull are you using?
            • LuckyDuc
              Team Ducati Racing
              • Dec 2008
              • 1058
              It is the setup I had planned to use in my Whip for LSH. I was concerned that the UL-1 motor would have a hard time pushing a 7lbs sport hydro around the course.
              • detox
                • 2357
                Check out this UL-1 powered White Whiplash. Whip is faster but he lost because of bad driving.
                • line6
                  • 510
                  Hay i was at that race lol. And if i remeber the driver of the whip was near blind in 1 eye that day. Because of eye surgery. Both are good runing boats
                  Jason sims
                    The BJ26 motor will handle a LOT more prop than the UL-1. The mistake most people make is to run too large a prop on the UL-1 motor and too small a prop on the BJ26. With a 150 amp ESC you should be able to handle the x645 with ease on a large hydro. While a UL-1 will work on a large heavy boat, the BJ is a better choice if you are willing to experiment with props. Note: blade area is your friend for higher efficiency and speeds. With some boats a detongued 1650 isn't too much....
                    • LuckyDuc
                      Team Ducati Racing
                      • Dec 2008
                      • 1058
                      That's what I was hoping. My m645 will be here this week and I should be able to start testing next week.
                      • detox
                        • 2357
                        From my experience the stock M645 is a poor performer when compaired to ABC's H series and S series props.
                        • LuckyDuc
                          Team Ducati Racing
                          • Dec 2008
                          • 1058
                          Really? I've never experimented with any ABC props.
                          • detox
                            • 2357
                            My castings are smaller than advertised. My S-15 actually measures 44.16MM. That's 5mm smaller than advertised measurement of 49mm.
                            • LuckyDuc
                              Team Ducati Racing
                              • Dec 2008
                              • 1058
                              That is strange. I wonder why their measurements are so far off.
