I rebuilt a boat a few months back and installed a Miss Vegas strut. I crafted my own strut bushing using 2 pieces of brass.. cut the slots in it etc etc. A few runs w/ that set up and a minute or so into a run it would begin to develop a whining sound. I actually thought at first I had a bearing going bad in the motor, but after a bench test with the motor out I found that it was fine and determined the annoying sound was from the strut. I thought maybe it was something I did wrong in the home built bushing, so I spent the insane amount of money on an AC bushing and had the same results. I changed out the brass bushing for a lead teflon and have had no problems since. My AC SV runs the factory strut bushing and is quiet as can be.
So I just finished a twin build using HOTR 4mm stingers. I drilled about 3/8 into the end using a 1/4" bit, and again, made my own bushings to allow 3/16 shafts and omit the 4mm stuff. First run was quiet as can be. But was only 45 seconds long before losing a prop. 2nd run, the whine developed and 3rd run its even worse. Im using Grim grease and tried adding oil w/ no results. Is this just a common problem w/ the brass bushings. Im thinking of going the led teflon route w/ these as well. But not having a drill press, Im hesitant to try and drill all the way through the stinger. If I drill it just a bit more, another 1/8 or so to give it approx 1/2" depth, is that spaced enough for the use of two lead teflon bushings in each stinger?
Thoughts?
Thoughts?
Also it spins extremely free when all is installed.. both drives.
