Opening a Neu 1515
  • V0RT3X
    • Jan 2009
    • 3
    Opening a Neu 1515
    Is the front endbell glued on? Need to replace bearings soon.
  • detox
    • 2357
    No... only the back plate is removable.
    • V0RT3X
      • Jan 2009
      • 3
      How? Heat it up and pull out? Can you replace the frontbell bearing?
      • Raydee
        • 1619
        Sent it back to Steve and have him replace the bearings and pin the end bell. He has done this for me a a few of my motors and had them back to me in less than a week. He hasn't let me down yet.
        Team Liquid Dash
        • MarkF
          dinogylipos.com
          • Mar 2008
          • 988
          In order to replace the front bearing you have to remove the rotor to get to it. Just make sure you keep track of the spacer washers so you put it all back together like the way it came out.
          Mark
          • V0RT3X
            • Jan 2009
            • 3
            Sadly I'm from Europe.
            Mark
            Is this the proper procedure?
            • MarkF
              dinogylipos.com
              • Mar 2008
              • 988
              Thats one way to do it. I just tap the front shaft on a piece of wood untill the endbell pops off. After you take the motor apart make sure you clean were all the glue was on the endbell and reassemble using a good locktite. It really is pretty easy.
              Mark
                Anyone have a link to good bearings for a 1515??
                I'm in Canada.
