Reverse Pistix?
  • tharmer
    • 342
    Reverse Pistix?
    I believe a Pistix lets a Pistol TX mimic a stick transmitter. Is there a device that lets a stick transmitter mimic a Pistol TX?
  • m4a1usr
    Fast Electric Addict
    • 2036
    A PiStix adapts the signal range of the A/C esc to within the range of a PG tx. An A/C esc likes 1.1ms to right around a 2ms range for a stick Tx but a PG Tx wants a 1.5ms to 2ms. Since the PG range is smaller then the A/C range there is no need for an adapter. It sees the entire pulse range. Is there another application you were thinking about?
    John
    Change is the one Constant
    • AndyKunz
      • Sep 2008
      • 1443
      You could enable the springs on your throttle stick.
      If you really need a reverse PiStix, I can change the code in it for you. E-mail me andy at montanadesign.com
      Andy
      Spektrum Development Team
      • tharmer
        • 342
        Well, the issue is the ESC's. Marine ESC's apparently are intended for Pistols. When the ones with automatic throttle adjustment (like my ETTI) start up, I end up with no throttle from half-stick down (I understand this) and a big jerk when I move the stick past half, then OK to full throttle. I can program the ESC and it works perfectly with my sticks until I disconnect the lipos for a new run. Then when the new lipos are installed and I try to run the boat, the ESC has forgotton about the programming, does an auto throttle adjustment, and I'm back where I started.
        What I'd like to get is the full stick movement from low throttle to high throttle, like it would work in any airplane.
        I can run Pistols if I have to, but it'd be neat if I could stay with my sticks (that I have used for about 40 years).
        -t
        If it starts to make sense, Andy, I'll get in touch. The new Pistols have some of the same functionality that my JR 10X has so maybe I should just sigh and surrenter to the 21st century.
        • m4a1usr
          • 2036
          Have you tried programming the esc using the throttle options instead of letting it go into auto programing? Throttle option #2 sounds like its for a stick Tx.
          John
          • JimClark
            • 5913
            Talk to Ron Daum he runs sticks
            Jim
            -t
            Billy Graham
            • AndyKunz
              • Sep 2008
              • 1443
              I have a 10X at work. If that's what you're using then it can be done with a throttle curve in the transmitter. I forget if that's available in Acro mode - you might have to be in Heli mode. I can check. I hardly ever use the 10X, it's mostly for reference, but the place is crawling with Team JR guys and I'm sure I can get a minute from one of them.
              PM me your phone number and I'll call you from work on Monday to walk you through it if you need help.
              Andy
