Changing Bearings on BJ26 Stock Motor
  • nckmat
    • Mar 2010
    • 1
    I have a BJ26 with at least one worn out bearing in the stock A3630-1500 motor; has anybody tried to change these bearings and if so how the hell do you open the motor can?
    Any advice would be appreciated.
    Nick
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1750
    Not 100% sure but it looks like the front end bell is threaded in and the back is deff. pressed in. Gonna be a 5mm I.D. bearing not sure about the O.D.
    • mappo
      • Feb 2010
      • 496
      I have removed both Bearings, first tap the shaft so the end bell will pop off, it is pressed in. i used a piece of wood, then you can remove the front by unscrewing, and just replace bearings. nothing to it!
      Do you know what the biggest problem with the world is?
      That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
      • tomstoys2
        • 637
        What replacement bearing did you use?
        Thanks,
        Tom
        • HYDROJERRY
          • Jan 2010
          • 2709
          I did the same with mine , got mine from Boaca bearings, when i get hope i can look to see if i can find my original package with the part#,,,
          • tomstoys2
            • 637
            Thanks Jerry,
            I'll take them out tonight. Thought they might be the same ones that go in the Feigao & Nemesis S, L & XL motors 11mm x 5mm x 5mm that Steven sells but wanted to be sure before ordering them.
            Tom
            • tomstoys2
              • 637
              I got the bottom off but can't budge the front. Any tricks?
              • blackcat26
                High Speed Junkie
                • Sep 2009
                • 1750
                Screw in two screws in the front endbell (not too far as to damage the windings) and clamp the screw heads in a vise (not tight) Then you should be able to get a good grip on em and unscrew the can.
                • HYDROJERRY
                  • Jan 2010
                  • 2709
                  Then once you get it off if the bearings dont pritty much fall out i used two 1/4'' sockets one on the inside bigg enough for the bear to fall into and one on the outside small enough to fit in the encap but tofit the bear and nock them out with a hammer...
                  • tomstoys2
                    • 637
                    Thanks.
