Proboat motor, normal behavier
  • Heath M
    • Mar 2008
    • 865
    Hi guys
    is it normal for a proboat motor should come to a dead stop when you release the throttle. Watch the attached video and you'll see what i mean.
    The esc is an Aquacraft 40amp, is there a way of programming it so the motor has a softer stop mode?
    Heath
    Brisbane,QLD, Aussie
  • sailr
    • 7128
    Normal. Proboat makes a programmer for their ESC but not for Aquacraft. Aquacraft doesn't let you program their controller at all.'
    Why are you worried about it?
    Mini Cat Racing USA
    www.minicatracingusa.com
    • Heath M
      • Mar 2008
      • 865
      Originally posted by sailr View Post
      'Why are you worried about it?
      Because it doesn't happen to any of the other guys running the same setup in our club.
      • BHChieftain
        Fast Electric Addict
        • 2051
        The ESC is probably set with "BRAKE ON". If it were a proboat ESC you could use the programming card to turn the brakes off-- that is the way I have it set on my Fastech and it coasts normally...
        -Chief
        • Heath M
          • Mar 2008
          • 865
          thanks for the reply, is there a way to do it with the transmitter ?
          • Make-a-Wake
            FE Rules!
            • 6057
            Im gonna venture a guess that the prop doesnt come to a dead stop while in the water and the boat is moving when you release the throttle. I more than likely slows and "brakes" the boat.
            • BHChieftain
              • 2051
              It depends on the ESC... Sailr indicated the aquacraft ESC isn't programmable. In that case, you'd need a different ESC. Hardly seems worth it, though!
              -Chief
              • m4a1usr
                • 2036
                Here is a little help. Never say never.
                John
                Change is the one Constant
                • Heath M
                  • Mar 2008
                  • 865
                  The prop does come to a complete stop in the water but obviously momentum keeps the boat moving.
                  Can't change esc's as its a spec racing class.
                  There must be a way to program it with the TX
                  • m4a1usr
                    • 2036
                    And this too.
                    John
                    • Heath M
                      • Mar 2008
                      • 865
                      Thanks John i'll give that a go.
                      BTW what is "wot" short for?
                      • m4a1usr
                        • 2036
                        Wide Open Throttle.
                        John
                        • ozzie-crawl
                          • Sep 2008
                          • 2943
                          wide open throttle "wot"
                          • Heath M
                            • Mar 2008
                            • 865
                            thanks boys :)
                            • Make-a-Wake
                              FE Rules!
                              • 6057
                              Ozzie, John beat you by five seconds...........................Just curious Heath, how are you certain the prop dead stops in the water at 30mph?
