Anyone use teflon tubing anymore?
  • boater76
    • 574
    Anyone use much of teflon tubing anymore?
  • sailr
    • 7128
    Not me. I use the exact size brass tubing that the flexshaft runs in freely. .187 shaft running inside 7/32" stuffing tube. Works great!
    Mini Cat Racing USA
    www.minicatracingusa.com
    • screwball
      • Jul 2009
      • 464
      i have it on all of my boats except my micro scat cat and the scat cat spins the smoothest imo
      • RandyatBBY
        • 3944
        I have quit using it on the hi-performance setups anything 2S and lower I still use it.
        Randy
        BBY Racing
        • raptor347
          • Jul 2007
          • 1177
          I still like teflon on the high rpm setups.
          Brian "Snowman" Buaas
          Team Castle Creations
          NAMBA FE Chairman
          • Darin Jordan
            • 9446
            I use it in all my heat racing setups, except for a couple of recent Rigger builds, where I'm running wire directly in brass, and exposed from the hull to the strut. Don't know how they'll hold up long term, but they seem to be doing fine thus far.
            I think teflon, properly lubed, keeps things quieter. When I think I'm losing power/speed due to teflon liners, I'll consider changing it... So far, no issues if installed correctly.
            Darin E. Jordan - Renton, WA
            • m4a1usr
              Fast Electric Addict
              • 2036
              I'm afraid I am still old school. No builds without a liner. When and if I decide to go wire I will probably not run a liner but since I am in no hurry its going to be awhile.
              John
              Change is the one Constant
              • crabstick
                • 955
                I personally never use it anymore.
                Matt.
                www.rcboats.co.nz
                • egneg
                  • 4759
                  I use it on flex but not on wire.
                  IMPBA 20481S D-12
                  • RandyatBBY
                    • 3944
                    Do not try it on a 1/4 drive system it will freeze up. I all most lost a 1/8 scale due to it and did loose a 2280 12T to teflon in a 1/4 flex shaft. Once burnt just a little skiddish.
                    Randy
                    BBY Racing
                    • Jeepers
                      • May 2007
                      • 2050
                      I still use teflon for my set ups I have tried both ways and prefer the teflon, plus it helps keep water out of the hull, thats more important to me.
