Lipo Question/help
  • NorthernBoater
    • 869
    #61
    Originally posted by Diegoboy View Post
    That is a direct quote from the previous mentioned link.
    It clearly says effect of splitting the current draw between each pack.
    It also says enabling a higher current draw
    Show me otherwise in black and white. not just 2 different packs. When combining multiple packs in parallel.
    I am not saying that. Paralleling will allow you to draw more current. Each battery will actually only see half the current. I just do not want some reading this forum that is new to get confused. If they try to parallel 2 packs and also think that the "C" rating is doubled from 10C to 20C along with doubling the mah capacity from 2000 to 4000. If they try to draw 20C from the parralled cells they will wreck cells.
    • Diegoboy
      • Mar 2007
      • 7443
      #62
      Too late...
      I already got confused.
      LOL
      Note to new people: Just because the packs are internally parallel, doesn't mean you can double the current/mAh/"C" listed on the pack. We are talking about more than one pack in parallel.
      • NorthernBoater
        • 869
        #63
        Originally posted by SJFE View Post
        Since this is a lipo question thread I'll add one of my own. Now I think this is how it works but I need some verification here before I spend some cash. If I take two 3s 11.1v 2400mah @ 12c & parallel them. I will then have 3s-6p 11.1v 4800mah with a 24c rating correct? Then if I take that set run it in series with another set Id get 22.2v s6-12p 4800mah @24c correct ??? Man I have a head ache. By the way total weight will still only be 612g. Total cost shipped 92.96 shipped per set. So for under the price of a singe Neu pack I can power the entire boat..For under the cost of 2 packs I can power the boat twice.... Just lookin for a safe lower cost sport setup to hold me over untill I can aford race packs this winter.
        What about the 10C Poly RC packs on Battlepacks. For a couple dollars more you would be able to get two 4000 mah packs.
        • SJFE
          • 4867
          #64
          they are twice the price @ 45 bucks a pop. They are what I had in mind first. But I found sets for the same price as a single pack. When I have more money I will pick them up. For now I have only one set of packs after selling off all my Nimh. I need numbers...will I get burned as so to speak...we will see.
          • SJFE
            • 4867
            #65
            Well I made the move & have 8 3s 11.1 2400mah packs on there way. Total shipped just over 185 bucks. I will post a test thread in a few weeks after we get home.
            • ace028
              • Aug 2007
              • 986
              #66
              I got a ques, I have a apogee 3800mah 2 cell pack, it is a 20c discharge and it says 76 continuous amps. I have seen other 20 c batteris but their continuous is about 46 amps. What is the deal with that? I'm a noob, please inform me lol
              Twin power =
              • Doug Smock
                • 5359
                #67
                They must be 2300s.
                Doug
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • Doozie870
                  • 970
                  #68
                  I read to expect 20+- cycles if you use the highest cont. C rating during discharge, go as big as you can afford Imo.
