hydra 240 lv & 10 xl question ?
  • lrm50
    • 91
    just built a 33 delta force With a hydra 240 lv and a 10xl feigao running on 6s 6100 and a x445 2 blade prop. What will happen with this set up?
    If you think you're fast. You're not!!!
  • knpc
    • 649
    That's almost 40,000 rpm! and the hydra lv may not last long on 6s. It will go like a raped ape, but I don't know for how long.
    That setup on 4s would probably be perfect and would put you in the mid to high 40s mph.
    Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
    • Boatman
      • 875
      You will have great fun for sure. Sounds like a great setup minus the prop. Start a bit smaller if you can. Should see speeds pushing high 50's if setup just right. With the 10XL like knpc stated it may not last as long as you would like and may need bearing change after the season but I think everything should hold just fine. Heck of a bunch of fun those DF boats are.
      EDIT: remember that is unloaded RPM so with a 445 prop you should end up right were you want to be.
      • lrm50
        • 91
        boat sure ran like a raped ape for about 2 days then the unthinkable happened UP IN SMOKE everything except the hull and hardware crap crap crap!!! I need help with another set up for same speed but reliable.
        • ReddyWatts
          • 1756
          The 445 prop on a (540 10XL) will smoke the motor with around 3000 watts. Always look at the WATT rating of a motor. The heat will kill the magnets and possibly the esc too.
          ReddyWatts fleet photo
          • lrm50
            • 91
            Reddywatts according to chart in # cells /motorkv/propsize/hullsize the set up I put in the 33 delta should have worked fine you wrote the chart . Please help me out
            • BakedMopar
              No Mo Slipah
              • Sep 2009
              • 1743
              I don't understand why you ask how would this setup work and then say you ran it for two days then smoked. Was the setup different when it smoked? A 445 prop is big with that setup. I would start with 40-42 if your set on 6s with minimal run time.
              We setup a 26"delta with 6s and a 8xl. Prop was a x637 with a little cup added. After a two minute run temps were all under 110*. This is not a reliable setup as the boat is really setup for 4s but it sure was fun for the camera.
              • lrm50
                • 91
                I asked the question about the set up to see the response I would get . The responses I got is exactly what happened. My next question is can I use a 11xl or 14 xl since I have them laying around on a hydra 120 HV? And boat was same set up for the to days
                • ReddyWatts
                  • 1756
                  It will work if you use a 437 prop. Start small and work up to the desired amps/watts.
                  • Rumdog
                    • 6667
                    A 437 prop will not push a 33" mono efficiently, at all.
                    • lrm50
                      • 91
                      I belive that small of a prop will cause the motor to have a High rpm issue and back to square 1 again
                      • ReddyWatts
                        • 1756
                        I agree and the chart recommends this setup in a smaller hull.
                        • Rumdog
                          • 6667
                          The weak link may well have been the lv hydra.
                          • lrm50
                            • 91
                            maybe so. They say you can run 6s on hydra lv but I belive they are more reliable on 4s I'll pick up 120hv for the 11xl and see what happens
                            • RIPFENCE
                              • Sep 2009
                              • 1577
                              if you search the threads you will see its common practice not to run a low voltage hydra on 6s lipo...even though its advertised that way..i did the same thing and it blew up..jut my 2 cents..it will be worth your money to invest in a high voltage esc you will be better off in the long run
                              "FE" STANDS FOR FRUSTRATING EXPLOSIONS
