Replacing Bearing on 580l
  • mappo
    • Feb 2010
    • 487
    Hi Has anyone replaced bearings on the 580l, does it get pushed out from the inside of the end plates?
    Do you know what the biggest problem with the world is?
    That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1598
    On OSE's homepage under Tips/Info you will find a section that is for Motor Tips and Info. It's the first article in that section. Steven sells high quality bearings made by Boca that are far superior to the factory bearings. (Product ID: boc-smr696c-yzz-nb2) 2 needed. Hope this helps!
    • m4a1usr
      Fast Electric Addict
      • 2032
      Every BL motor I have worked on, Fiegao, hacker, neu, lehner, nemesis, Keda, yada..yada,... the list continues, needs the bearings pressed in towards the rotor if you were looking at it assembled. What that means is you need to remove at least one end plate (usually the front /output shaft side) to change out the bearings. Its actually an easy job providing you have the right tools. You can push pretty much anywhere on the bearings to get it out of the faceplate. But you cannot and must not apply any pressure or strain on the inner part of the bearing when reinstalling the new bearing. That would be side loading the inner race and impact from a hammer can easily exceed the load rating and damage the inner bearings or misalign the inner/outer races.
      So to answer your question you would technicly be pushing inwards on the bearing when looking at the outer end plates.
      Hope this helps.
      John
      Change is the one Constant
      • blackcat26
        High Speed Junkie
        • Sep 2009
        • 1598
        John you are the man, you know your stuff!
