Here are the stats.
8s / 28.8 volts , 12L 580 motor. 33" DF (knock off), 120HV Castle ESC
1st - x337 (3blade) 68amps
2nd - x337 70.55 amps, 2070wp, 30mph ( I moved the CG foward, ran wetter)
3rd - x442 101.34 amps, 3042wp, 44.7mph
4th - M445 - 129 amps, 3820wp, 38.4mph
5th run after all the HELP here.
M445 - 126,62 anps, 3727wp, 54.2mph! (The trim tabs got me a whopping 16mph!!!)...
So, does 44.7mph seem reasonable to you on the 3rd run? What I found interesting was that last run was way more amps, more prop, slower speed?? Can the GPS be sometimes less accurate? On the 4th run it "felt" faster, but the numbers say otherwise. I have the CG pushed back pretty far, just looking for top speed. I am kicking out a fairly large rooster tail, possibly I need to turn the strut down just a bit? Looking for suggestions and advice. I am shooting for low 50's as a goal.
This is my first time to a high voltage set up. MUCH cooler temps, no heat issues at all.
