1415 water jacket
  • andym
    More Go Than Show Prop Co
    • 2454
    1415 water jacket
    Hi guy's and gal's, doing a slight rebuild of my Raptor and want to go with a 1415 1.5D motor these are 36.5mm diameter the Fiegao are 35.8mm. I do not think the oring on my cooling jacket from the fiegao will handle being squashed the extra .7mm. Any idea's ??
  • ozzie-crawl
    • Sep 2008
    • 2943
    should go on with a little lube, or do you have a bearing shop in town they usually have a huge range of o rings
    • andym
      • 2454
      Got plenty of lube mate!! Seriously though the orings on the black cooling jackets are a very thin cross section already, I doubt if I can get the same OD with a .3mm thinner section. I think it will squeeze on but need to get the motor first. Just thought I would ask if any one has one cooled up ready to tell how they went.
      • RcBum
        • Mar 2010
        • 71
        KY should do the trick LOL
        • CornelP
          • 793
          The internal diameter of the Feigao cooling jacket is 36.2mm (just measured)...
          • ozzie-crawl
            • Sep 2008
            • 2943
            you may have to get a carbon fibre one from andrewg
            • jcald2000
              • 786
              The UL1 Water jacket fit my Old 1415 very well.
              • sailr
                • 7128
                according to OSE website, the Feigao 540 jacket will also fit the 1415
                http://www.offshoreelectrics.com/sea...e=&scat=&sman=
                Mini Cat Racing USA
                www.minicatracingusa.com
                • m4a1usr
                  Fast Electric Addict
                  • 2036
                  Those 1415 Neu's are a good deal for the money. What I would do to adapt a water jacket is find something that will fit inside the jacket, piece of PVC pipe/ tool socket/ wooden dowel, etc and wrap some sand paper around it. Slide it inside and get busy. Once you cut down the inner diameter enough, seal the edges with silicone /RTV sealant. Only thing I dont like about the 1415's is the end bells have no openings to allow convection cooling but for $169 it would be worth it and size the motor conservatively so heat buildup was not a problem.
                  John
                  Change is the one Constant
                  • ozzie-crawl
                    • Sep 2008
                    • 2943
                    andrewg sells the carbon fibre ones for $12,for that $$$ its not really worth stuffing around
                    • Steven Vaccaro
                      Administrator
                      • 8932
                      The ose jackets with the thin o-rings will not fit the neu 1415.
                      This ham jacket with the larger o-rings fits.
                      http://www.offshoreelectrics.com/pro...ham-jack-540XL
                      Steven Vaccaro
                      • raptor347
                        • Jul 2007
                        • 1177
                        I'm running a 1409/1.5D in my N2 sport boat. It runs STRONG for a small motor. I got the feigao style jacket on but it was seriously tight.
                        That 1415/1.5D in the Raptor is going to be scary.
                        That's the same kV I ran in my old P hydro to a 22.05 second 2 lap record a couple years ago. That boat didn't handle anywhere near as well as a raptor does.
                        I'd probably start with an H-4 cut to 40mm and back cut .090" at the hub. I'll be a beast. A bone stock ABC 1616 wouldn't be bad either.
                        Brian "Snowman" Buaas
                        Team Castle Creations
                        NAMBA FE Chairman
                        • andym
                          • 2454
                          Brian I can only agree but what fun!! No seriously this is the best handling rigger I have ever had, have moved CG back to 40% of after plane and even on a rough pond at near 65mph it runs true as an arrow !! I can see no reason why this could not go into the 70's in race trim. I know everyone is JAE mad at the moment and mine was built from plans not the kit but the Raptor is a stronger and better behaved boat in my opinion, not that that is worth much !!
                          • raptor347
                            • Jul 2007
                            • 1177
                            The JAE is a very different boat from the Raptor. They definitely fit different markets. I'm glad the JAE is available, I couldn't deliver 100's of boat kits in only a couple months. It's getting more people racing riggers and it is a very capable boat.
                            The Raptor is more than capable of running in the 70's.
                            NAMBA FE Chairman
                            • detox
                              • 2357
                              www.HRC-MFG.com makes the UL-1 jacket that OSE sells. He can make you a custom version with your choice of water inlet/outlet locations.
                              How about a Nue 1412 1Y (2750kv) powered by 3s. Wouldn't the smaller Y version pull less amps?
