ESC for 1521 1.5d
  • bedrock
    • Aug 2009
    • 248
    ESC for 1521 1.5d
    Hi all
    Any sugestions for a ESC for a 1521 1.5d unerstand that this is an amp hog!!
    Looking for 60mph plus in a Drifter M
    fried a CC 240 ???
    thanks
    Dean
    ________
    BUY EASY VAPE
    • 7990
    I have two and run them in both my P Sport Hydro and P Mono, the Hydra240s have worked great with no problems. Be sure to set the timing advance to between 0-4 degrees, more just adds heat.
    60 mph is possible in a cat, but run time may be limited due to heat buildup. Start with an x450, then try an x648 or P235.
    • T.S.Davis
      • 6228
      X646 works pretty well too.
      Noisy person
      • Ctonez
        • Jul 2007
        • 404
        I've used a Barracuda 125 for 2 seasons w/ a 1521 1.5D on 4S with no issues.
        It does limit how much prop I can use, currently a 447 I think.
        This year I'd like to prop up a bit so I am using the CC HV180...haven't tried it yet though.
        this is in a Pmono.
        • RaceMechaniX
          • 2825
          I assume you are running it on 4S, 6S will fry the esc with medium set-ups in a heartbeat. I have a 2151 1.5D, 1D and 0.5Y and all have run with correct prop. I used to cook the 240's pretty regularily, but I added the Etti cap bank and these has helped considerably on hot set-ups. Haven't fried one after I added the caps.
          Other more robust options would be a Schulze 32.200wk or the 40.300wk, but those are probably out of the question due to cost.
          Tyler
          Tyler Garrard
          NAMBA 639/IMPBA 20525
          T-Hydro @ 142.94mph former WR
