I have seen some struts that have a small hole in the side . Can i assume this is for lubing the flexshaft ?. If that is what it is for i was thinking about drilling a small hole in the strut of my sv27 & my out rigger . Any opinions ?.
Greasing your flex shaft ?.
It will only lube the shaft in the strut. I put them in the bearing struts so a person can fill with oil before running.
ALWAYS clean and lube the flex every couple of runs. I use a white lith grease synthetic from walmart in the boat section and then I puts drops of oil down it. Makes it very slick. I have also used Chainsaw Bar oil...very sticky and made for clinging on a saw chain...works well. Then there is stop smoke motor honey lube you can get cheap at a dollar general....thick and slick.
So you put oil in the bearing strut in stead of grease ?.Originally posted by Jeff Wohlt View PostIt will only lube the shaft in the strut. I put them in the bearing struts so a person can fill with oil before running.
Not on NON bearing struts. I am talking real bearings. For anything else I grease and oil...makes a good combo.
Do you drill the hole all the way thru the strut housing or just thru one side of the housing & bushing ?. Also were is the best location to drill the hole ?. I assume in the middle is probably the best . Also what size hole should i drill in the strut ?.Originally posted by Jeff Wohlt View PostNot on NON bearing struts. I am talking real bearings. For anything else I grease and oil...makes a good combo.Last edited by rchippie; 03-10-2010, 02:12 PM.
Yes i understand that . I figured the hole would be used if im at the lake all day . Then i could just squirt a little grease in the strut in between full maintenance sessions. Is it best put put the hole in the middle of the strut , also how big of a hole is recomended ?.Originally posted by BHChieftain View PostTo clarify, you still need to remove the flexdrive to grease the full length, as Jeff points out this hole only gets grease in the strut.
-Chief
I took out my drill bits to see how big the hole is on the fastech-- looks pretty close to 5/64. The hole is in the middle of the strut.Originally posted by rchippie View PostYes i understand that . I figured the hole would be used if im at the lake all day . Then i could just squirt a little grease in the strut in between full maintenance sessions. Is it best put put the hole in the middle of the strut , also how big of a hole is recomended ?.
Note, I use this grease gun:
http://www.offshoreelectrics.com/pro...rod=dh-prb0100
Might want to get the gun first, then start small and enlarge a bit at a time to fit the grease nozzle.
-Chief
Thank you thats the info i neededOriginally posted by BHChieftain View PostI took out my drill bits to see how big the hole is on the fastech-- looks pretty close to 5/64. The hole is in the middle of the strut.
-Chief
Doesnt matter whose strut you are talking about the hole in the strut is for release of the lubrication material to exit as heat builds. Over pressureization here is the factor. Since lubricant expansion is the issue the purpose is solely to facilitate possible issues related to adequate lubrication and bearing movement as temperature increases.Originally posted by BHChieftain View PostOn the proboat fastech, that is what the hole is for.
-Chief
In simple terms you dont want the bearings/races to push outward with increasing temps due to heating of lubrication materials and therefore increasing friction on the rotating components. The hole allows the pressure to escape. Very basic engineering.
JohnChange is the one Constant
Can i assume the hole in the strut only goes thru one side not all the way thru both sides ?.Originally posted by BHChieftain View PostI took out my drill bits to see how big the hole is on the fastech-- looks pretty close to 5/64. The hole is in the middle of the strut.
-Chief
For bearing struts it also dispells water after a run and keeps the bearings lubed.
When greasing after a run it does the same thing....pushes the water out. I prefer to remove mine and do it right when running bushings. Bearings need a little different treatment.
