fiberglassing ABS?
  • boater76
    • 574
    Whoops someone beat me to it. My bad.
    • sailr
      • 7128
      I tried that too and had problems. It is not a ratio by weight but a ratio by VOLUME. The hardener or resin, I don't remember which, is heavier than the other one! When you get into 2:1 or 4:1, etc. it can mess you up good. Not too big a deal with 1:1 and especially if mixing small quantities.
      Originally posted by CornelP View Post
      For the mixing, just get a cheapo digital scale. I got a 500g jeweler one, with 0.1g resolution, good enough for resin.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • CornelP
        • 793
        You're right here, but most resins will say the ratio by weight in the instructions... at least mine does. Resin is usually heavier.
        • Jesse J
          scale FE enthusiast
          • 7818
          ya, the guy sold me some pumps that can stay in the cans for years and give you exact volumes; plus the super clean dispensing ... the way to go.
          "Look good doin' it"
          See the fleet
          • sailr
            • 7128
            Interesting. None of the resins I have ever used mentioned weight.
            Mini Cat Racing USA
            • Jesse J
              scale FE enthusiast
              • 7818
              My local distributor says that he does use weight but only for small amounts, while the pumps give you exactly the amount you need right in your container. He did say that if you wanted to use the scales you could and he didn't think one was denser than the other; just that it is way less convenient that way.
              See the fleet
              • Jeepers
                • May 2007
                • 2050
                I wouldn't waste my time with 3m to tack it down, the fiber glass will eventually come off, been there, done that, tried that, it lasted for about 1 season of racing and then started pulling off especially in the hot sun.
                • Jesse J
                  scale FE enthusiast
                  • 7818
                  You sayin the glass will come off BECAUSE of the 3M or just come of anyway? Being on the inside, I was gonna coat it also with sprayfoam for added rigidity.
                  Jeepers, how did you prep your work? could it have been a slightly dirty surface or not scuffed? or new abs... I am wondering if between 3M and CA I can get the glass to stick enough to not come loose later...
                  See the fleet
