Originally posted by sailr
View Post
Running in salt water
Hi Sailr, I have both gas and FE boats. I have started another thread here http://forums.offshoreelectrics.com/...ad.php?t=13191 on the basic things I do to each boat.
Hi Chuck. Yep, I grease the heck out of the shaft and I use a piece of fuel tubing or shrink on the inside like you say. Still get some water in that way. Maybe I need to start using some heavier grease!
I don't use liners either and use the smallest size stuffing tube that the flexshaft will turn freely in. I don't use a sponge, I use a tampax! You wouldn't believe how much water those suckers will soak up!
Originally posted by Chuck E Cheese View Postslair. if your stuffing tube is sealed to the strut and you dont have alot of play between the shaft and stuffing tube (or liner) a heavy layer of grease will keep it out. i know this for sure because o put sponge under the stuffing tube at the inside opening and it is dry. make sure you arent using too big of a tube as i know you dont like to use liners. you can also use a piece of heat shrink on the inside, shrink it with the shaft in and about 3 turns of the motor and it will be zero drag and lessen the tolerance between the shaft and tube. also remember that a few drops is OK, it is several drops that starts to get things wet. also the small piece of sponge keeps water from getting to anything.Mini Cat Racing USA
www.minicatracingusa.com
Mind you, I'm pretty new to this hobby, but I wrapped my reciever with Glad Press and Seal plastic wrap and taped the leads with electrical tape-- I once capsized the boat in the middle of the lake outside of fishing pole rescue range. I didn't tape the hull correctly and it filled completely with water (only the tip of the hull was above the water line) . When it finally drifted to shore 4 hours later, I removed the radio from the wrap and it was completely dry. I think I'll keep using that method!Originally posted by m4a1usr View PostWhich brings up a tip for any wanting a cheap water proof balloon. Cut the finger off of a latex glove. They will stretch over most small receivers and are just long enough for the antenna and leads comming out to seal. Tie it off with a zip tie. Then put a wrap of 1" wide electrical tape aound the circumfernce and you have a surface to attach your velcro to.
John
-Chief
I have one or two boats that stay pretty dry but most of them and most of the others I race with can't keep a boat bone dry inside either.
