ammo... 2600
  • sharkbite
    • Aug 2009
    • 392
    ammo... 2600
    hay all...
    Can i run the ammo 2600 with the aquacraft 60 amp esc?
  • Make-a-Wake
    FE Rules!
    • 6057
    You'd be cuttin' it close............very minimal "comfort" room. Prop it conservatively and you may be able to. Specs on the 2600kv.....you may already know
    Input Voltage: 11.1-14.8V
    Max. Constant Current: 55A
    Max. Surge Current: 90A
    Max. Constant Watts: 815W
    • Rumdog
      • 6667
      No. Not with any prop that will load the motor enough. Not enough esc for a 2600 540 size motor. I'm assuming you're thinking 4s also...
      • Make-a-Wake
        FE Rules!
        • 6057
        I'd suggest the 2030kv 36x56 at the most, as the 2600kv is just too much motor as rumdog has stated............i thought it was too close as well. If you have an older 60a esc the caps are really weak to start with..............i've had three replaced for free, they now have the "new" caps as you can see in red ink on the site for the 60a.
        http://www.offshoreelectrics.com/pro...qug7001&cat=14
        • sharkbite
          • Aug 2009
          • 392
          some of my friends bought some and going to put them in the ul-1. I have the H&M viper with the ul-1 motor and the cc 120 and its faster then the stock ul-1
          • Make-a-Wake
            FE Rules!
            • 6057
            You have a Castle 120a with the 2600? That should really fly! Your friends may not like the result of running the 2600 with the 60a.
            • sharkbite
              • Aug 2009
              • 392
              No. I have the 120 cc with the 2030kv in the viper and it flys.
