Should I off-set flexshaft driveline?
  • kevakov
    • 111
    Working on a Mean Machine FE build and have noticed pictures of other builds where the driveline is offset, just a small amount. The offset is to the right, is this for a oval racing setup? I'm used to right hand turns in oval form, but many MM builds have the driveline centered in the hull. Which way is best?
  • Rumdog
    • 6667
    Centered. Offset doesn't do much of anything in a cat that wide. The mean machines turn extremely well!
    • crabstick
      • 955
      I tend to offset to allow for prop torque, not as important on the mean machine as rumdog says, on my gas cat and the majority of my boats, specially hydros and vee's the driveline is offset to the right
      Matt.
      www.rcboats.co.nz
      • ozzie-crawl
        • Sep 2008
        • 2943
        my MM is centre, turns extremely well
          Offsetting the prop has nothing to do with turning. Offsetting the prop to the right tries to point the hull to the left. This counteracts prop walk so the rudder stays straight without any drag-inducing trim.
          With the MeanMachine offsetting the drive line helps a lot with high-power setups - offset 3/16" to 1/4" depending on prop size. If you have to use left trim to go straight, then offsetting can help regardless of the hull type.
          • crabstick
            • 955
            nothing more frustrating than having to put left rudder in to make the boat run straight, knowing its robbing you of speed.
            Matt.
            www.rcboats.co.nz
            • ozzie-crawl
              • Sep 2008
              • 2943
              yes i should of said handles well not steers well,i don't use any trim it drives straight
              but iam only using a 8xl and a small prop
              • kevakov
                • 111
                If we do run with an offset is it parallel with the sponsons with no angle at all and squared up with the hull?
                • AndyKunz
                  • Sep 2008
                  • 1444
                  There are two thoughts on that. Some run them parallel to the sponsons, just offset to the right. This gives the hull drag that's on the left more mechanical advantage, helping the boat to track straighter.
                  I keep my motor centered (because the tub isn't wide enough to do otherwise) and angle the entire driveline to the left.
                  Both methods work.
                  Andy
                  Spektrum Development Team
                  • kevakov
                    • 111
                    Thanks Andy, the MM has plenty of room to run offset parallel, so I think I will be square on this one !
