Are thrust bearings used on brushless motors? If so are they used on all or just some?
Thrust bearing for brushless motor?
The need for a thrust bearing is required when side loading is a known problem. Defined as axial loading. Typical radial roller bearings used in electrical motors do not function well when they are loaded in the wrong direction in which they were designed for. Spalling occurs and destroys the roller bearing pretty fast. Not all brushless motors are going to need a thrust bearing, because it depends on how much push or pull is being generated from the flex assy.
JohnChange is the one Constant
I am using a ammo 2300 with a .150 flex cable do I need a thrust bearing? And if I do do I need to get a different flex shaft coupler because I do not thing I can get the coupler down on the shaft to sandwich a thrust bearing?
Thanks
http://www.offshoreelectrics.com/pro...?prod=dh-53136 CANT HURT , I ALWAYS RUN THEM . PREVENTS PUSHING THE MOTOR ENDS OFF THE CANS..
