Bby hooters tunnel spec opc
  • RandyatBBY
    • 3943
    Originally posted by Dan Proulx View Post
    That Randy Naylor...he's a genius!
    Your too kind. If I could only spell
    Randy
    BBY Racing
    • BILL OXIDEAN
      • Sep 2008
      • 1561
      Man, you aint Lyin' there.. The boy can design a radio controlled model watercraft that's for DANG sure.
      I've yet to see a design of his that didn't work exceptionally well.
      Always been a great platform for me to tweak in my setup. This boat planes out and flies like a hydro.
      I'm not sure if I'm supposed to divulge this, but in initial testing the ABS version of this tunnel chased down a hydro like a dog in the street both running the blue SV27 pspec systems!!!
      • BILL OXIDEAN
        • Sep 2008
        • 1561
        Originally posted by ozzie-crawl View Post
        yep i am a metal fabricator so triangulation is a big part of my trade
        i was thinking its for out rite speed runs,prop set back to act like a longer hull.
        isnt the hinge pin suppose to be inside the rear of the sponsors ?
        triangulation thank you spell check
        Ok, now I know what you mean, and you by no means come off as a smart alleck..
        The pin is closer to the drive because there would be FAR too much pivot involved, and the push pull rods would undergo far too much stress as well as the servo.
        Just picture it and you'll understand.. The boat would probably hook immensely as well.
        • ozzie-crawl
          • Sep 2008
          • 2943
          thanks bill
          yes i see how its done,what i was trying to ask was i am under they impression that for a tunnel to turn well, they pivotal point should be inside the rear of the sponsons.
          not sure were i got this assumption. but as they say "assumption is the mother of all **** ups"
          • rchippie
            • Jan 2010
            • 640
            Does the carbon hull handle any different than the abs hull, also how strong is the abs hull ?.
            • RandyatBBY
              • 3943
              The weight is about the same but the strength is much better with the FG. Edges are sharper So over all better handling.
              Randy
              BBY Racing
              • rchippie
                • Jan 2010
                • 640
                So is your less exspensive tunnel fiberglass ?. I thought it was abs plastic.
                • rchippie
                  • Jan 2010
                  • 640
                  Randy when you get time can you answer this ?.
                  • RandyatBBY
                    • 3943
                    Styrene plastic is $69.95 Fiberglass is $160.00 and the Full CF is $199.00
                    Randy
                    BBY Racing
                    • BILL OXIDEAN
                      • Sep 2008
                      • 1561
                      thanks bill
                      Assumptions also solves problems with these things,
                      so your assuming things isn't a bad thing..
                      • RandyatBBY
                        • 3943
                        So will did you get some paint on this boat yet?
                        Randy
                        BBY Racing
