Need some BL conversion advice PLEEZE
  • BondoBrushless
    • Feb 2010
    • 156
    New to the forum and I'd greatly appreciate some help and advice.
    I own a 48" Aeromarine DeepVee with a 30cc Homelight and the boat does very well, Unfortunately my worn out old shoulder causes me a lot of pain pull starting so I'd like to convert it to Brushless.
    I am very BL/Lipo savy but with RC Monster Truck conversions so the BL boat thing is all new to me. I have a NEU 1527 1500kv motor that I think would be a great candidate for this ? I'd like to run 10s and will be purchasing either a Castle HV ESC or maybe try a 200amp ESC from another Co thats much cheaper ?
    The questions are as follows;
    Will I be able to use the same props I have now
    Whos motor mount will best fit my boat, custom fabbing and modding NOT a problem
    Any responses with advice or suggestions will fall on open ears, I'm still learning the boat lingo and techniques so please bare with me.
    Thank You Gentlemen
    Jeff
  • Rumdog
    • 6667
    That motor is a 6s max motor, 10s is waaay too much voltage.
      • 7512
      The 1527 is a bit small for a hull that size.
      • BondoBrushless
        • Feb 2010
        • 156
        40volts max
        Really ? Hmmm that sux
        My buddy has a light weight 40" Steve Muss mono hull he wants me to look at tonight. I'll take some pics and see what you gurus think about it on maybe 8s w/a appropiate Speedo
        • Steven Vaccaro
          Administrator
          • 8932
          I agree that the 1527 is to small. But I think you will be able to run it, but not at record speeds. A 1527 is good for about 1.5-2hp for short runs. So your speeds, props and runtime will be much lower than what you are accustomed to. Take a look at this motor for your hull. http://www.offshoreelectrics.com/pro...ls-63outrunner
          Steven Vaccaro
            • 7512
            "Really ? Hmmm that sux
            My buddy has a light weight 40" Steve Muss mono hull he wants me to look at tonight. I'll take some pics and see what you gurus think about it on maybe 8s w/a appropiate Speedo"
            Now you're getting warmer, One of our club members is running a 39" mono with that motor on 6S and it runs really well.
            • BondoBrushless
              • Feb 2010
              • 156
              I have no problem buying another motor and this one above is def cheap enough !
              Then I can save my 1527 for a RC Truck project
              Keep the advice coming fellas, I post pics of the Muss hull tonight.
              Thank You !!
              • sailr
                • 7128
                Another approach is to get an electric starter for your gas engine. You'll have to google for it. I know somebody out there makes them. Not trying to run you away from FE, but another option an ultimately probably cheaper.
                Mini Cat Racing USA
                www.minicatracingusa.com
                • Rumdog
                  • 6667
                  "40volts max" Not on that motor.
                  That's 60,000 unloaded rpm. Waaaaay Too high.
                  • ozzie-crawl
                    • Sep 2008
                    • 2943
                    neu make a motor that is a replacement for the zenoah engines.
                    neu 1900zr puts out 4-5 hp and spins to around 18,000 rpm under load on 10s
                    • BondoBrushless
                      • Feb 2010
                      • 156
                      Ya know, funny thing is I own 7 NEU motors and never thought to look in the Neu Boat section DOH!
                      If this 40" hull looks nice I'm gonna order up a Castle ESC and get going on my new project And sell my Aeromarine w/motor.
                      Thanks Ozzie !
                      • BondoBrushless
                        • Feb 2010
                        • 156
                        OK, heres the boat I'm gonna go with, forgot the name but it's brand new with no holes even for rigging. Scored for $50.00, weighs 4.4lbs and is 42" long.
                        8s and the 1527 1.5 should be a good combo ????
                        Whatcha think ???
                        OBTW, the other boat I spoke about is a "Steve Maus" I was real nice but paper thin, I wouldn't trust myself w/it being that light.
                        • Rumdog
                          • 6667
                          I'm still gonna say that is way too much voltage for a 1500kv motor unless running saws only. I'm sure others will tell you the same.
                          • BondoBrushless
                            • Feb 2010
                            • 156
                            I admit I don't know everything about BL motors so I'm having trouble understanding why 30volts is to much when rated for 40 ?
                            This motor will take 8s in a 16+lb RC Monster Truck geared for 40-45mph will zero problems or heat issues.
                            Help me understand what your talking about ?
                            Look on the 5th line in the first box, says rated up to 8s with this motor ?
                            • Flying Scotsman
                              Fast Electric Adict!
                              • 5195
                              Boats are very demanding on the motor, ESC and batteries. A monster truck is no comparison as you will be be at full specs and more on the electronics in a boat. I have no experience on a hull of that size, you will need the help of some big boat gurus and it is going to be quite expensive to convert. You will need a motor with a lot of torque and if the motor states up to 8S, reduce that to 6S, 10S reduce to 8S and the same applies to the ESC.
                              Douggie
