HPR06 motors ?
  • tiqueman
    • Jul 2009
    • 5866
    HPR06 motors ?
    I can only imagine the grief I may get on this, but having been unemployed for close to a year now... Im VERY limited on options, and its killing me not having this boat in the water yet.
    So, Ive got 2 Etti 150 2-7S ESCs...
    On HPR06 fansite, there is a setup using the 540 8Xl Feigao on 5S. Im thinking I may do this until I can afford to power it differently.. or if I need to power it differently. On that site it states its getting a lilltle over 100 kph.. so roughly mid 60s. I know Fecalc isnt perfect.. its only an idea.. and it having no "twins" set up.. but, running it thru on the calc, 5S, 8XL, 440/3, it roughly pulls 137 amps.
    My question is, would I be better off with a 9XL on 6S... FEcalc shows a few more mph at 136 amps (1 less amp). How risky is it for a couple mph to put the voltage that much closer to max on the Etti. I do not have the extra caps installed. Would that be a good idea no matter what I run?
    Again, I know Neu, Lehner.. etc etc is the way to go, but I have to work off what I have and what I can get much less expensively until I can find work.
    19 boats down.. FRANKs "NO FEAR" boat http://hpr06.speedtoy.com/setup.htm
  • Rumdog
    • 6667
    10xl on 6s will be a lot cooler setup, and still fly!
    • tiqueman
      • Jul 2009
      • 5866
      1 vote for a 10XL. And I see your point.. much less amps.
      And the Etti will be ok on 6s. What about the additional cap bank?
      • Rumdog
        • 6667
        extra caps is always good insurance
        • tiqueman
          • Jul 2009
          • 5866
          I also see the Feigao's max voltage is 6S... is that too much pushing the limits of the motor?
          I wont be racing it, just sport boating in my pond, but Id like it to "fly" I was thinking mid 50s would be great (for now) But 60s is much better.
          • tth
            • Apr 2008
            • 1600
            I ran a 10xl in a rigger on 6s with the etti 150 like you have and had no issues at all. Definately install cap banks. If you have a basic electronics knowledge you can build one.
            • Rumdog
              • 6667
              the max voltage is all relative to the motor kva 7xl will most definately be 4s max where as a higher turn motor can more efficiently run higher voltage with less amp draw.
              • tiqueman
                • Jul 2009
                • 5866
                Well put.. makes perfect sense.
                tth, thats what I wanted to hear
                • vvviivvv
                  • 1148
                  when i get my next lot of batts i can lob two 8xl's in my hpr... when its built (week or 2 more max) with the eagle tree and logg it for you... what props where u planning all mine are maybe too big for 8xl's tho ( prop shop 4518/3 and 4713/2 )
                  Uk SAW record holder
                  • tiqueman
                    • Jul 2009
                    • 5866
                    That would be great! Octura 442 counter rotating.
                    For some reason I thought you could get the 440/3 in a right hand rotation... nope.. I was wrong. I was hoping to run cr 3 blades, even if it doesnt help the performance, they just look mean Guess I got to start shoppin!
                    Thanks again, Im lookin forward to the results
                    • vvviivvv
                      • 1148
                      ill try my best to get you them asap ill have to acuire a x442 lr tho or run on a 47 and if amps are ok you will be ok on a 42 a few bits and bobs to do on the boat then ill order the rest of my batts this weekend and see what i can get for you... my logger is brand new oll have to figure it out
                      • vvviivvv
                        • 1148
                        propshop has an equivalent to 440/3 in l + r and there available in stainless steel... there beast! ill post a pic of mine when i get some decent lighting
                        edit: i could run 2x x442 rh just to get amps even if it torque rolled
                        • tiqueman
                          • Jul 2009
                          • 5866
                          Great thank you! Im going to check into the PS props now.
                          • Himalaya
                            • Apr 2009
                            • 259
                            Try the Castle-Neu 1518, IMO it's a better motor for a bit less, or Medusa 3680 if you can still find a pair, unbeatable performance to price ratio. Also their are Neu-alike motors from China, I have two of those and am going to try in my HPR06 when the lake melts up if I can finish the build in time.
                            • Andrewg
                              • 26
                              With the Feigaos make your max about 90 amp peaks. After about 80 amps a lot of any imp[ut is simply being turned into heat
                              A properly setup 43" twin cat will run over 65mph+ with 5 cells per side, 10xl's and 47mm blades.
                              With good motors think 75-80mph
                              Andrew Gilchrist
                              www.fastelectrics.com
                              right first time solutions
