There is talk of an N2 hydro class here next season, what is generally considered a reliable, motor and controller, lipo combo?
N2 power question
a awesome setup is a H and M viper with a hacker 7L on a hacker master 70 running a nice and big X642.
it's a screamer
And some are running 6XLs 120s and 645s, 2s2p 5000s.
I haven't built one yet, I'm still watching.:D
DougMODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
For a lower-cost setup, I'd go for the 6L Nemesis and Hydra 120....
I've run both the Neu 1515 1D (4100KV) and 1515 0.5Y (about 4500KV) in my Banzai HydroSport 28 experimental..., both with good results... Same combo SCREAMS in an N2-Mono as well... all on 2S2P and a B125 ESC...
Also, if your boat is lighter, the Neu 1509 1.5D (4500KV) works GREAT... just doesn't have the torque of the 1515 motors...Darin E. Jordan - Renton, WA
How long are your races? You might be pushing it if you're running a full mill and 1 mile. Darin can tell you for sure.Originally posted by Doozie870 View PostIm looking at two of the 2500 2s 25c packs, would 5000 mah be enough safety factor?
IMPBA President
IMPBA 19887L CD
NAMBA 1169
they are running at twice the voltage sooo, figure double their mah usage. watts used will be the same. prop size, strut setting, and how the boat runs('dry/wet') all affect the amps used(not to mention type of boat), your boat may not pull as many amps as mine...but its a good idea to start conservatively with your testing. also note I'm getting my figures from what the charger is putting back, actual mah use should be somewhat lower.Still waiting for my boat to come in.it came in
Allright. I ordered two 3700 25c 7.4 flight power packs with two balancers. The reason for going with this brand is to use up my store credit from the lsh who mainly deals with tower. After talking with flightpower my understanding is, I can use a y harness to charge both packs together at 2C and that the balancer will shut off each pack accordingly. Not sure how it does this when they are being charged through the output leads, also not sure what happens when one pack shuts off and now the other is getting 2c instead of 1c. but here we go!
