Schulze ESC
  • nova68
    • 211
    Schulze ESC
    I have a Delta Force Sniper 45, I am going to run a NEU 2215/2Y on 8S2P and I need a ESC. I am looking at 3 Schulze, fut-I-32.115WK or fut-I-40.100WK or fut-I-40.160WK, Can some body help I think the fut-I-40.160WK is the best but I would like some input.
    • 7512
    Its pretty bullit proof,,,but has no LVC for LiPos so you will have time your runs appropriately.
    • domwilson
      • 4412
      You can use one of these for LVC. It goes to 12s... http://www.dimensionengineering.com/LipoShield.htm
      Government Moto:
        You will not regret getting the 40-160. In the future you may want to run 10S, and the 32-cell versions are risky at that voltage. Too, 100 amps is too low for your setup, a bit too much prop and you may have toast. The resale on the 40-160 is also very good, the others not so much.
        • nova68
          • 211
          schulze ESC
          Will I have a problem with 2.4GHz set up?
            • 7512
            No.
            • RaceMechaniX
              • 3024
              There is also the 32.200. If you are never going to run 10S, that might be the better option.
              The 40.160 is a workhorse though, can't go wrong there.
              Tyler
              Tyler Garrard
              NAMBA 639/IMPBA 20525
              T-Hydro @ 142.94mph former WR
                No.
                Actually you might. The 40-160 and 32-170 (at least) do not run with the HRS mode offered in the FASST system. They work great with the FASST's PPM mode however.
                • RaceMechaniX
                  • 3024
                  I believe the new versions are OK with HRS mode, after reading the instructions it appears they work with HRS mode:
                  From the Future instructions:
                  Pulse times Allowed range: 0.8 ms ... 2.5 ms
                  Cycle time: 4 ms (HRS mode) ... 30 ms
                  Tyler Garrard
                  • nova68
                    • 211
                    Were is the best place to by a Schulze ? And do I need to program it for any thing or buy a program card ?
                    • RaceMechaniX
                      • 3024
                      I recently just bought mine from Icare RC
                      ICARE, electrics, electric accessories, motor controller, brushless motor
                      For the water cooled esc's you can purchase the USB ADAPT UNI which allows you to change programming options.
                      http://www.schulze-elektronik-gmbh.com/index_uk.htm
                      Tyler Garrard
