Paralell adaptor(what size bullets?)
  • forescott
    Hopelessly Addicted to RC
    • 2686
    Does anyone know what size bullets I can fit 2-12ga. wires into?? Looking to build a paralell adaptor for 4s2p into my turnigy 180. Thanks!!
  • RaceMechaniX
    • 2825
    Look for 8mm bullets. Steve sells these as does cheapbatterypacks.com
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • Rumdog
      • 6453
      You will only nedd 5 or 5.5 mm max, unless your pulling huge amp #'s
      • Brod
        • 196
        These are as big as you want to go,fits 12ga wire well,cheap too.
        http://hobbycity.com/hobbycity/store...s_(10pair/20pc)
        Slow gets boring fast.
        • forescott
          • 2686
          Yeah, but understand that I want to fit (2) 12ga. wires into (1) bullet connector.
          • Rumdog
            • 6453
            why?
            • egneg
              • 4664
              Why not use adapters for this.
              IMPBA 20481S D-12
              • forescott
                • 2686
                How did you do that??????
                • forescott
                  • 2686
                  I am looking for the cleanest way to run 2 turnigy 4s lipos(10ga. wires) paralell, into my turnigy 180a esc. I want to use bullet connectors and I like the EC5 connectors from losi. But I am open to any suggestions. So I will have 2-10ga posotive wires and 2-10ga. negative wires going into 1-12ga. posotive and 1-12ga. negative wire from the esc. Not sure how to accomplish this.
                  • Rumdog
                    • 6453
                    All I did was strip some insul., and solder a short piece of wire to the main wire while weaving some of the strands together.
                    • SpeedoMan
                      • Jul 2007
                      • 6
                      Thats 8awg wire isn't???
                      • egneg
                        • 4664
                        Here is a picture of the basic assembly, I soldered 8 awg wire in each male connector and then soldered it to the female connectors. I leave a bit extra with insulation to hold the 8 awg together and cut off the extra when done. Then I use heat shrink to cover it up.
                        IMPBA 20481S D-12
