Originally posted by calcagno45
View Post
Scorpion Motors
please specify comp.
hi i think this site is for positive info not rc boat politics please state which company has an prog card that is infared and it not sold separately, or like this system mr steven posted check out the site get the info then reply.it's easy to be a critic very easy.rreyes.
Did they improve the 300A esc's after some people tested them ?
Boat went "full=throttle" , the driver is a very very SKILLED man.
After this happened he immediately went back to his Schulze's.
Ops sorry for the mistakes, from what I've know for hk 4020 - 1390kv max rpm is 35,000rpm, dont remember where I get, maybe u can get it by googlingOriginally posted by calcagno45 View PostI was asking about total RPM, no kv, like Voltage times KV = RPM.Stiletto tunnel,EPV135 (53") twin cat, CT06"Spirit of Qatar", FD 47" mono, Twin Mini Cat 23.5"
So using the bearings that you've suggested, it require no lubrication at all?, as most scorpion stock bearing need lubrication if it were to be use frequently.Originally posted by icelert View PostI would also suggest carrying some high quality sealed bearings to get better performance and lower maintenance. I have found the Boca stainless/ceramic Lightning series bearings a good choice in the Scorpion motors.Stiletto tunnel,EPV135 (53") twin cat, CT06"Spirit of Qatar", FD 47" mono, Twin Mini Cat 23.5"
thanks for info Ub Hauled, appreciatedOriginally posted by Ub Hauled View Post4020/1390....
max amps = 90
max watts = 1890
1890/90 = 21v (or 6s approximately)
22.2v* 1390 = 30,858
source: Scorpionsys.com
Steven he is a very expierencend builder and driver and had never before and after a glitch .Originally posted by Steven Vaccaro View PostFor my own knowledge, how does a person find out if there is a radio glitch or an esc glitch?
The boat is still running with the same Hardware with 40160Schulze
Greetings
Axel
I'm not questioning his professionalism. But a question for my knowledge, how does a person rule out which area a problem is happening when it could be the esc or radio system.Originally posted by axel View PostSteven he is a very expierencend builder and driver and had never before and after a glitch .
Greetings
AxelSteven Vaccaro
