Timing numbers to use on a Black Jack motor
  • TRUCKPULL
    • 3293
    I am looking to find the timing numbers to use on a Black Jack motor??
    With a Black Jack ESC all you get is LOW and HIGH
    I want to use a CC 80 ESC
    What timing should I use for LSO class??
    What timing should I use for LSH class??
    Larry
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    Larry, I've got my Titan 29 set up for P-Spec LSO with the Blackjack motor and a CC 80 [ watercooled, heavy batt wires & big caps] running Turnigy 4S 3600 2P. Since rumor has it that the Blackjack speedo is 11 degrees advance, I set the CC 80 to 11 degrees also. I have a humongo fan blowing on the motor & SC, BTW. With a hub-cut X442, temps after 3.5 mins were good and batt consumption was adequate for 4 min + full mill. I now have de-tounged the X442 & mildly cupped it & set the CG back @ 3/4 inch to loosen it up some. Should be better, I'll know more Sunday & Eagle tree again.
    LSH boats run way looser so a few more degrees shouldn't hurt temps. Depends a lot on prop loading.
    • TRUCKPULL
      • 3293
      Thank You Tony
      Let me know after SUN.
      Larry
      • tiletony
        • 203
        larry are you running the blackjack motor or the entire boat?
        • TRUCKPULL
          • 3293
          I run a Titan 29 in LSO right now.
          Larry
          • sailr
            • 7128
            run the 6 pole Aquacraft and BJ motors at 11-12 degrees timing.
            Mini Cat Racing USA
            www.minicatracingusa.com
