Lipo Safe Proto
  • ReddyWatts
    • 1756
    A person might want to think about keeping the lipo batteries in separate containers or bags. If one goes, they all might go!
    From what I have read the ABC or BC class extinguishers should work on a lipo (class C-electrical) fire???
    ReddyWatts fleet photo
    • Doug Smock
      • 5359
      Originally posted by ReddyWatts View Post
      So what kind of fire extinguisher does it take to put out a lipo fire? A regular A, B, C extinguisher will not work?
      That is good information.
      Reddy,
      I looked real quick and can't find the information. As I recall it was a "K" rated extinguisher that was recommended. Or, good old sand.
      Doug
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • ReddyWatts
        • 1756
        Class K is for industrial "K"itchen fires. It is expensive because it leaves no residue. Uses halotron gas.
        • Doug Smock
          • 5359
          That may be a good idea I don't know.
          Some of the LiPo vids I have seen where people have shorted cells or overcharged cells to the point of failure, ( Fire) there were single cells that survived a fire within the pack.
          I'm still on the fence on this one.
          Doug
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • Doug Smock
            • 5359
            MSDS
            INDEX
            K Class Fire Extinguisher Chemical
            1. IDENTIFICATION
            Manufacturer: Flag Fire Equipment
            Hwy #2 & Patillo Road, RR#1
            Tecumseh, Ontario N8N 2L9
            Emergency Phone: (519)727-6722
            Technical Information: (519)727-6722
            Chemical Name: Potassium Acetate & Potassium Citrate; Potassium Salt
            Chemical Family: Mixture
            Formula:
            Identifier: Fire Extinguisher K Class Wet Chemical Model F260
            Fire Extinguisher Chemical Charge K Class Model F530
            Product Use: Used in the application of extinguishing fires in commercial kitchens.
            2. INGREDIENTS
            Hazardous Ingredients: % Cas# LD50 LC50
            Potassium Acetate >90 127-98-2 3250 mg/kg None established
            Potassium Citrate <10 866-84-2
            Other Ingredients:
            None
            Fire extinguishers contain compressed air to ensure a high velocity discharge of product. WHMIS Class A. HMIS 1-0-0 NFPA 1-0-0
            3. PHYSICAL DATA
            Physical State: Liquid
            Odour and Appearance: Odourless, clear liquid
            Odour Threshold (ppm): Not applicable
            Vapour Pressure (mm Hg): Not applicable
            Evaporation Rate: None
            Boiling Point: Not applicable
            Freezing Point: Not applicable
            pH: 10-11 pure, 8.5-9.0 mixed
            Specific Gravity: 1.3 (as mixed)
            Solubility in Water: 72.5% @ 20°C
            4. FIRE & EXPLOSION HAZARD DATA
            Flash Point (°C) and Method:: Non-flammable
            Means of Extinction: None required
            Upper Flammable Point: Not applicable
            Lower Flammable Point: Not applicable
            Auto Ignition Temperature (°C) Not applicable
            Hazardous Combustion Products: None known
            Explosion Data:
            Sensitivity to Impact:
            Sensitivity to Static Discharge: Not applicable
            Not applicable
            5. REACTIVITY DATA
            Stability: Stable
            Conditions to avoid: Do not mix with strong acids, strong oxidizers and strong caustics.
            Hazardous Polymerization: Will not occur.
            6. TOXICOLOGICAL PROPERTIES
            Effects of Overexposure: AAt high concentrations, irritation of eyes and skin by chemical or mechanical action may occur.
            Exposure Limits: Not available
            Irritancy of Product: Not available
            Sensitization to Product: Not available
            Carcinogenicity: None
            Teratogenicity: None
            Reproductive Toxicity: None
            Mutagenicity: None
            Synergistic Products: Not available
            7. PREVENTATIVE MEASURES
            Gloves: Wear rubber gloves.
            Respirator: None required unless oxygen level is below 19.5%.
            Footwear: None required.
            Clothing: None specified
            Eyewear: Safety glasses
            Engineering Controls: Adequate ventilation should be available, use fans or vent to outside. Maintain oxygen levels of 19.5% minimum.
            Leak and Spill Procedure: Ensure clean-up is performed by trained personnel only. Sweep up dry material for disposal. Flush residue with water.
            Waste Disposal: Review federal, provincial/state and local government requirements prior to disposal. Disposal by local hazardous waste authority.
            Handling Procedures: Avoid container damage.
            Storage Requirements: Cool dry areas.
            Special Shipping Information: If pressurized Fire Extinguisher Class 2.2 UN #1044
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • ReddyWatts
              • 1756
              WOW! that is a lot of information. I just dont understand why we would need a K extinguisher on a lipo fire? ABC is supposed to extinguish all fires and sand will work. They are just not clean methods. Leaves a big mess.
              • Doug Smock
                • 5359
                Yes I understand.
                I am going to concentrate on "just saying no" to LiPo fires,and just be as safe as one can be.
                My son and I agreed this weekend that we will have no conversations while we are putting cells in a boat or on the chargers. It is just too easy to make a really stupid mistake that could possibly be life altering.
                I think these cells are actually pretty safe if we just use common sense. I will continue to keep them in a safe place, not push them,( run2p setups ) and carry that bucket of sand. LOL
                On the other side. I have a friend that flies and has for years. He has loose cells in his garage, basement, mini van, and in his office. He has never had a problem.
                I just don't see myself going there.
                If you do find more information about extinguishers, I would be interested in knowing.
                Thanks,
                Doug
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • ReddyWatts
                  • 1756
                  Better let your son carry the bucket of sand! lol!!!
                  • Doug Smock
                    • 5359
                    I'm still in pretty good shape for an old man. LOL
                    Doug
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • SJFE
                      • 4867
                      Final product
                      Well I took delivery of the box today. I am quite pleased with it. I put it on the scale and it's 22 pounds even. The pictures speak for them selves. The next one is still under construction and is spoken for. I really don't plan any more unless some one is interested. They are not very cheap. They take about 7 hours to complete.
