Twin Jollycat
  • showstoppercat
    • May 2007
    • 95
    Twin Jollycat
    WoW!! WoW!!WoW!! - Watch an Awesome Boat - First run today - Just running a basic 8s setup (4s eachside) nothing to ballistic yet - but the sound of those twin feiago 10L's is just awesome didnt go flat out lipo placement was perfect & the wedge work great sending up a Fantastic Rooster Tail...... Love Cats
  • Eodman
    • 1285
    Yeah and it just gets better!
    Unfortunately my driving skills are not great ... so I'm a little apprehensive to drive it hard into the corners! Mine is running on 8xls, 4s per side and it runs real well!
    I find I drive my MM harder - but that may be the cost factor is lower! The Jolly has about $1600.00 in it and the MM only $6 or 700 in it!
    We did it with a Bang!
    Cats Are Where It's At!
    • showstoppercat
      • May 2007
      • 95
      How can i get this cat into the Hi 50-60+ mph range without bustin the budget anyone????
      • justintime2w8
        • 323
        More cells and/or the right props. More/less pitch more/less diameter. I have not run this particular cat but your gear should get you there.
        Just feed everyone here your setup; prop size, prop height, angle, ect. and readings; temps ect. Then they can help you squeeze a bit more out of it.
        www.radtekpowerboats.com
        • showstoppercat
          • May 2007
          • 95
          My current TWIN drive setup: 540 10L 2,602 RPM / Volt - Graupner K Series 40mm
          Pitch 1.4x40=56mm or 2.20" (smallest counter rotating props I can get my hands on) - Castle Creations Hydra 120 - Just touching 50mph how can i get this meow to 60mph????
