need help with a lipo
  • old guy
    • 687
    Hi I have a Hyperion 3s 1800mAh lite Storm vx 20c. OK it is sitting at 9.8volts and I'm trying to run it through a Hyperion EOS0606i-B on store. ass soon as I hook it up it comes up Balancer voltage too high. I tried to charge it but it would not let me. so what is up and what do I do?? any help would be nice
    Thanks Rick
  • old guy
    • 687
    any one have any idea?? Mr watts any one I'm just a old nitro guy lost in a sea off FE boats. Help
    Old Guy
    • vvviivvv
      • 1100
      is it reading it as a 2s?
      Uk SAW record holder
      • sailr
        • Nov 2007
        • 6924
        Did you set the charger up to charge 2S or 3S? Check that first. Doesn't your charger also have a discharge cycle? You could try discharging the battery a little bit and then trying again.
        Mini Cat Racing USA
        www.minicatracingusa.com
        • old guy
          • 687
          as soon as I hook it up it comes up Balancer voltage too high and will not let me do any thing I have the charger set up for 3 cells and 1800mah???
          Old Guy
          I just did 10 lipos this way and this one was about number 6 so as I did the other lipos I put the funny one on a balancer for a day and it still comes up the same
          • westbeach
            OSE Rocks!
            • 951
            You should be able to plug in your battery to your charger without having to hook up the balancer to discharge the battery. Give that a try, if not take your boat or what have you for a quick spin to discharge the batteries.
            Old Guy
            HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
            • old guy
              • 687
              OK I will but a 3s lipo is 11.1 and am at 9.8 but hay I will try any thing now
              old guy
              • westbeach
                OSE Rocks!
                • 951
                Old Guy, remember that you are discharging the battery not charging!!
                • westbeach
                  OSE Rocks!
                  • 951
                  Rick,
                  I see that you are in BC. Where?
                  • old guy
                    • 687
                    OK I discharged the lipo. It only was on for about a minute and a half then tride to hook it back up and it started to yell at me again. some times 65% nitro in a cut is not so bad lol so now what
                    I live in Ft St John mile 48 of the Alaska hwy
                    Old Guy
                    • westbeach
                      OSE Rocks!
                      • 951
                      Rick, try doing a full cycle of discharge first then charge her up. Without a balancer attached.
                      Must not be too many FE boaters up there other than yourself? Are others running nitro/gassers?
                      • old guy
                        • 687
                        Ok it done and this is what I got
                        charge 62.07 01180
                        LP 89ma 12.559V
                        and it is a bit puffy so I think it history
                        no one up here in to boats but me all car and rock crallers and planes
                        • old guy
                          • 687
                          well got home from work to day and it is so puffy it is going to explode so it's going out side in the snow untill I go to work. I have never seen one like that I'm glad it was in my clay charging pot. thanks for the help
                          Old Guy
                          • westbeach
                            OSE Rocks!
                            • 951
                            Rick, sorry to hear about your lipos. At least you didn't burn your boat or house! I guess you get to treat yourself to some new ones
                            • old guy
                              • 687
                              Just had to look at it, so cut it open and only 1 sell was bad. got the wires off any reason why I can't make it in to a 2s for my rock crawler it was a 3s 1800 so would I not get a 2s 1200 just would not have the balance plug. but shuld be good for a rock crawler with a brushless motor.
                              Old GUY
