New Crackerbox?
Interesting. Although it's a little hard to tell in the picture, it looks like the pictured boat has hardware that places the prop past the back of the transom, which doesn't conform to the consensus that was decided on. If bought as a bare hull, the underhull straight shaft could, of course be rigged.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Seems that in 2007 Rego at RC Boatworks [Stryker] built some & Ken says that with a CMB .21 they ran in the mid-forties, stable and turned great. I'll see what more I can find out.
Mooooooahhhhhh haaaa haaa haa haOriginally posted by properchopper View PostSeems that in 2007 Rego at RC Boatworks [Stryker] built some & Ken says that with a CMB .21 they ran in the mid-forties, stable and turned great. I'll see what more I can find out.
Go Sherlock Holmes or is it 007?:::::::::::::::. It's NEVER fast enough! .:::::::::::::::
Most days it's more like Inspector Jacques ClouseauOriginally posted by Ub Hauled View PostMooooooahhhhhh haaaa haaa haa ha
I e-mailed Ken last night; will let you know what info comes back.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Hey Guys,
Ken Wiley and I both race at Camarillo and I have seen this mini crackers run. They are very nicely built, simple and easy to set-up. Ken and Rigo have had these for at least 2 years now, so I don't think they were aware of the 1/6 scale cracker rules proposed for FE.
His cracker would probably be appropriate for P type power systems. It would also work well in a lite set-up running a 1/10 scale or 1/8 scale car type power system.
TylerTyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
Thanks Tyler,
I did a little research about the hulls and I came across the CPR (Camarillo Pond Rats) guys
on their site there are a couple of other shots of the hulls in the water, certainly nice to look at.
Tyler, did you have a chance to see their drive line? can you tell us what it's like?:::::::::::::::. It's NEVER fast enough! .:::::::::::::::
Tyler, Is Ken the gent who had the two really tasty crackerboxes pitted next to you at the last SAW's ?Originally posted by RaceMechaniX View PostHey Guys,
Tyler2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Tony, Jan,
You are thinking of Mike Brown. He has the super nice gas crackers. Those are not Ken Wiley crackers. The Blue one in Mikes own design and the wood one is a Blazer Marine design modified for NAMBA rules.
Jan, the small crackers would have a similar drivline to a cat where the cable would exit through the bottom of the hull and have a slight bend. I believe the rails are glassed in at 4", but I am pretty sure Rigo could leave the rails out.
Sealing may be a slight issue as there are no lips , but lots surface area to tape.
TylerTyler Garrard
Good stuff, Tyler. One thing though, the current agreed-upon setup for the proposed 1/6 P-Spec Cracker class is a straight underhull driveline with the prop [or is it the drive dog ? can't remember which at the moment] not extending past the transom.
Do you think Ken's hulls would lend themselves to this setup ?2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
I haven't looked at the rules, but I take it straight being literal solid shaft set-up.
Yes, I suppose you could.
TylerTyler Garrard
