Prop(s) for a Shovelnose
  • Karfrik
    • Jun 2009
    • 1248
    its a fiberglass Maus/Bandit i just bought used here in OSE.It will be powered by a SV27 motor on a 90a Turnigy esc,2S-3S lipos running on a .150 flex.
    What would be the ideal prop(s) for this setup?.......thanks,....Albert/karfrik
  • Jeepers
    • May 2007
    • 2050
    well that motor likes to run on 4s 2x 2s packs in series 42-45mm prop would be good!
    • Karfrik
      • Jun 2009
      • 1248
      bump!! any more suggestions?...someone told me i need a prop with higher pitch for the shovel hydro in order to stick the front up.If so which ones in specific?....thanks,...........Albert
      • JimClark
        • 5913
        I am reworking one also and am getting a prather 215 and an X442, X642 and a couple of other smaller ones to play with
        I should add mine is goign to have a BJ26 motor
        Billy Graham
        • egneg
          • 4759
          I have a Campbell classic hydro and use a Prather 215 but the motor is an ammo 2300 kv you might want to try a Prather 220 with your motor.
          IMPBA 20481S D-12
          • Karfrik
            • Jun 2009
            • 1248
            Well,the SV27 motor didn`t materialized but was offered,by the same seller,an Ammo 2300 too.So thats what i`m getting.
            What Esc`s are you guys using? I`m thinking on getting either a Turnigy 90A or 120A.Which ones would you guys suggest? the Marine version(more expensive) or the waterproof one(cheaper)?
            Lipos are going to be 2S 20C-25C 5000mah for now.
            And Jim what kind Hydro(size) are you reworking?......
            Egneg,the Campbell is around 22-24" right?......................thanks guys,Albert
            • JimClark
              • 5913
              It is a maus shovel 24 inches
              This is the hull I have
              Jim
              Billy Graham
              • Karfrik
                • Jun 2009
                • 1248
                Jim,same hull as me....Thanks for the picture!!
                egneg,whats the rotation on the Ammo?...
                And what size lipos are you guys running? also let me know about your esc`s actually on them and what you think about the Turnigys i mentioned if any experience with them.Any suggestions on this?
                Here are couple pics of mine.Already did a template for the tailfin that will be added, plus i`m planning on changing sponsors...... .....Albert
                • JimClark
                  • 5913
                  I am going to use 2 2S 4500 to 5000 mah lipos in mine with a BJ26 motor
                  I modified the sponsons to change the dihedral to 3.5 degrees and will repaint it with a generic paint job.
                  jim
                  Billy Graham
                  • egneg
                    • 4759
                    Here is a video that has the info the rotation is left hand - thanks to Diego he did the video.
                    IMPBA 20481S D-12
                    • Karfrik
                      • Jun 2009
                      • 1248
                      Wow that thing is fast and beautiful!!! was that on only 1-2S lipo pack or 2 of them?...
                      On the Ammo motor,by rotating left you mean counter clockwise right?....Thanks much for the video,.........seems I`m ready to finish buying the stuff i need thanks to you guys,............Albert
                      • egneg
                        • 4759
                        It is 2 x 2S packs in series and yes it is standard rotation.
                        IMPBA 20481S D-12
                        • Karfrik
                          • Jun 2009
                          • 1248
                          Hi again guys,need to know where to get my water pickup for the esc.The rudder is not such equipped,so should i go with a transom setup or can i use a bottom hull one?..thanks again,....Albert
                          • JimClark
                            • 5913
                            Billy Graham
                            • Karfrik
                              • Jun 2009
                              • 1248
                              Custom made,right.....not bad.Thanks Jim,will take it in consideration......Albert
