hydra 240 temp range?
  • tiletony
    • 203
    Are those 8mm connectors to the es and 6 or something similar to the batteries? Do you know what the best firmware to run on the 240
    • Raydee
      • 1619
      I have no problems with 5.5mm bullets and even though I was dead set against running V1.04 firmware I believe all my setups are running better with 1.04 compared to 1.03. The timing values were all wrong with 1.03. Don't be afraid to try different timing value's with the 1.04 firmware until you find the one that runs the coolest and the best.
      I found that with my New 1515 1Y motor running the timing on low caused everything to run hotter than running the timing on High. Instead of just setting the timing to a certain value I do some short runs on all the timing value's and find the one that works the best for my boat and setup.
      Team Liquid Dash
      • tiletony
        • 203
        I will try that. I was afraid I might kill something running on high but I will. Try it. I will try that firware also thanks!
        • Raydee
          • 1619
          Just keep the runs short and check your temps after each run. If I remember correctly (been a while since I ran a Feigao motor) changing the timing didn't make a huge difference. I think I always ran mine on Normal timing. Feigao motors are pretty inefficient so they run on the warm side.
          Team Liquid Dash
